Results 1 to 17 of 17
    Apr 2009
    Pennsylvania
    P0327-Knock Sensor Circuit Low Voltage
    So i replaced the knock sensors and the harness and the wire from the PCM to the harness, even put new pins in the PCM connector that I got from the GM dealer. Oh and by the way, i replaced the PCM as well.
    I am still getting P0327 knock sensor circuit low voltage. I followed the instructions in the following site. GearChatter.com :: View topic - DTC P0327 Knock Sensor (KS) 1 Circuit
    I am out of ideas.
    Does anyone know what the voltage is supose to be????? What is the minimum/maximum voltage.
    Thanks
    Apr 2009
    Pennsylvania
    I read that the code will active when the voltage is below .500v. I disconnected the pigtail harness and read both the sensors. While reving the engine, the i seen the voltage go up to around .400v. Is this right?
    I just looked at the knock sensors. The original part number on the Knock sensor is 10456603.
    The new knock sensors I have installed are 12589867.
    Member 383ls6's Avatar
    Nov 2009
    dallas,texas
    2002 z/28
    1. Inspect the terminals at the Knock Sensor (KS) jumper harness connector located on the left side of the intake manifold for a connection problem.
    2. Check the resistance of the KS from the Dark Blue wire, pin A to ground.The front sensor is the Dark Blue wire and the rear is the Light Blue wire Should be 93-107K ohms.
    3. If OK reconnect the connector.
    4. Disconnect the Red connector at the Powertrain Control Module (PCM) and recheck resistance from the Dark Blue wire, pin 51.
    I have installed new delco knock sensors and gotten a bad one out of the box. also dont overtorque them.
    Apr 2009
    Pennsylvania
    Quote Originally Posted by 383ls6 View Post
    383ls6, i have done the exact troubleshooting procedure you just wrote 100 times in a row. According to the readings, everything is good.
    Apr 2009
    Pennsylvania
    These are the readings I am getting. Can someone give me some readings off your car so I can do a compare since I cannot find any min/max numbers.
    They go in the order of
    Bank 1 resistance
    Attachment 25052
    Bank 1 mv at Idle
    Attachment 25053
    Bank 1 mv at 2000 rpm
    Attachment 25054
    Bank 2 resistance
    Attachment 25055
    Bank 2 mv at idle
    Attachment 25056
    Bank 2 mv at 2000 rpm
    Attachment 25057
    Nov 2009
    dallas,texas
    2002 z/28
    wow thought i might be able to help you but those readings look perfect.as soon as you clear the code it comes right back? i know its a pain but you might try pulling the intake again and swap the sensors front to back and see if you get a p0332 now then you would now its a sensor problem or something else. if you still get the p0327 then you would know its not a sensor but plug or wiring. even though its reading right could still be a sensor. thats where i would start. torque is 15 lb/ft
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    Ive had this problem and was told it will happen if you dont use the proper brand knock sensors, i think theyre supposed to be AC Delco. It can also happen if the harness get pinched when you install the intake manifold
    I have also heard of members having issues with non-AC Delco sensors. OP -- what brand sensors did you use?
    Apr 2009
    Pennsylvania
    I have replaced the sensors twice. I have purchased them straight from 2 different dealership. AC delco 12589867. which replaces the old 10456603.
    Apr 2009
    Pennsylvania
    The code comes back after a couple miles of driving but sometimes it comes back after roughly 10 miles of driving. I always torque the sensors to 15 lb/ft.
    The car is not stock, the modifications are g5x3, ARP head studs, AFR 205 heads, cometic .040 head gaskets, comp cam 921 springs, 7.4 push rods, yella terra lifters, rollmaster double roller, ls6 ported oil pump, 1/7/8 tsp headers, tsp catted ypipe.
    Right now i have a ls6 intake with stock throttle body on the car but i had a fast 102 with a nick william throttle body but took it off because i thought it might be causing some sort of issues. But that wasnt it.
    Hope this helps, i am out of ideas.
    Nov 2009
    dallas,texas
    2002 z/28
    do you have access to a scan tool?
    Apr 2009
    Pennsylvania
    Yes, i have HP tuners and VCM Scanner. The car runs smooth with no knock. I have tried to make knock as recommended by a tuner i talked to and see if KR activates and it does, so that tells me that the knock sensors are working. I really think that they are picking up false knock but I do not know how to tune the knock sensor and I have not seen any write up. I do not want to just disable them.
    Do you know a way that I can check to see if the knock sensors are functioning correctly? Do you know how I can tune them?
    In HP Tuners, there are tables for tuning the knock sensors. It appears that Frost adjusted mine as part of the mail order tune. Settings are under <Engine>, <Spark Control>, and then <Knock Sensors>. You will then see tabs for setting both the level and gain.
    Apr 2009
    Pennsylvania
    I have the mail order tune from Frost and i did a compare and he changed the knock sensor data in the new program. Please keep in mind that i would never say anything bad about Frost because when the code is not on, the car runs great. Its just this code that is giving me the problem. Every troubleshooting guide I have found and performed, the knock sensors are working correctly.
    Nov 2009
    dallas,texas
    2002 z/28
    sorry man didnt realize you had a tuned pcm. thats over my head. post up when you get it figured out.
    Apr 2009
    Pennsylvania
    will do. Thanks for your support.
    Junior Member Mr_Rich's Avatar
    Santa Maria, California
    1998 Pontiac Formula LS6
    Did you back probe the leads to get those readings? Not the way to do it. Make it simple for yourself. The knock sensors on my '98 read 1000 ohms resistance. When I installed my intake on the new engine almost two years ago I pinched the harness on one of the nubs of the valley cover. I had 0 ohms on the front KS and 1000 ohms on the rear KS. Quite a few people have done it besides myself. I unplugged the harness and set the meter to the resistance setting and checked the KS terminal at the plug to ground. I had Weatherpak connectors and fixed the harness myself. No problem since.
  1. knock sensor code with new knock sensors?
    By zaaronz in forum General Help
    Last Post: 02-27-2011, 06:26 AM
  2. circuit 2 sensor 2?
    By pk222 in forum General Help
    Last Post: 12-21-2009, 09:33 AM
  3. Help: Low Voltage to knock sensor
    By 2k-Trans in forum General Help
    Last Post: 10-15-2009, 05:27 AM
  4. P0327 Knock Sensor - Performance??
    By desliger in forum General Help
    Last Post: 10-02-2009, 03:21 PM
  5. High voltage O2 sensor Circuit
    By ss~zoso~ss in forum External Engine
    Last Post: 06-19-2008, 11:49 AM
