Results 1 to 3 of 3
Thread: Moser Ring and Pinion Gears
06-16-2008, 08:29 AM #1Junior Member
- Apr 2008
- RI
Hey guys just like a few opinions I am swapping my gears on my '02 SS going to 3.73's and I am stuck between Motive and Moser...relatively both are priced the same@ around 180's so I was just looking for some feedback on a Moser setup if anyone currently has them in their Camaro. Thanks...
NBT,
06-17-2008, 06:23 AM #2
The Motive Performance gears are generally better than the regular Motive gears (I'm getting a set put in this weekend). It's been said that they're pretty sturdy & relatively quiet, compared to other gears.
The absolute best gears I've heard about are the AAM gears (GM's supplier). Randy's Ring & Pinion has Yukon gears (which use AAM as a supplier) for under $200 - might be worth a look. Wish I would've known about them before I bought my Motives.
06-17-2008, 07:36 PM #3
I like my AAM/3.73,( running about 2 years/only about 5 k miles )they will be 2 cut gear set up a little diff than reg 5 cut
chk page 41-42
GEAR SETUP
http://www.aam.com/file.php/255/axle+shaft+brochure.pdf
my .02' JohnnyY2K SS (SLP #239)
Completly STOCK heads/bore/stroke/weight
& NOTHING else ---is stock
"NAW-NAW- just a Sunday goto meeting car, my best time is not in the 12's------- any more "
ps: I am not soliticing work as I am retired
>>>info on alignments
http://www.jgruggles.com
OEM GM 3.42 ring and pinion gears, used
By 2000SSM6 in forum Parts For Sale / TradeReplies: 5Last Post: 07-06-2013, 09:08 AM -
Anyone know who makes Summit ring & pinion gears?
By rel3rd in forum DrivetrainReplies: 0Last Post: 09-07-2008, 03:09 PM -
RING and PINION???
By 1bad99ss in forum DrivetrainReplies: 12Last Post: 01-04-2007, 06:48 PM -
fs: 3:42 ring and pinion
By luch900 in forum Parts For Sale / TradeReplies: 0Last Post: 08-02-2006, 05:57 AM -
Ring and Pinion install?
By chevelle9 in forum LT1Replies: 3Last Post: 11-03-2005, 05:20 AM
