Results 1 to 13 of 13
Thread: RING and PINION???
12-31-2006, 04:30 AM #1
RING and PINION???
my 99 SS has 3:23s and im going to change the gears and i was wanting to get 4:10s. i was going to get 3:73s but ive been told i should go with 4:10s cuz it will make one hell of a difference.
99 ss m6 #256 & 2002 Hayabusa/ 176rwhp
12-31-2006, 06:58 AM #2Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
A4 you should prol go with a stall and tranny cooler along with some 3.73 gears. Best upgrade for you is to slap a stall in the 3200 range on there to maximize the benefits of the new gears.
12-31-2006, 02:04 PM #3
I wouldn't go with 4.10's in an A4 car unless you are only using it for the track. Its just too much gear for daily driving, your fuel economy will go to hell and you'll be turning some ridiculous RPM's in 4th gear, especially on the highway.
I'd reccommend going with 3.73's, getting a stall converter, and installing a trans cooler. That will net you a nice performance gain.
01-01-2007, 05:25 AM #4
i forgot to add that it is a 6 speed
01-01-2007, 08:26 AM #5Senior Member
- Jul 2005
- Earth
4.10s will make one hell of a diff. M6 cars are harder to launch with 4.10s, but once you get rolling they are more fun. 2 problems however. 1. You will eat a ton of gas with them. 2. They tend to break stock 10 bolts if launched improperly or with sticky tires. They have smaller teeth, thus you will be looking for a 12 bolt or 9 inch in the future.
01-01-2007, 05:32 PM #6
Dont rule out 3.90's either, kinda an in between ratio if your undecided.
01-01-2007, 07:10 PM #7
01-01-2007, 09:42 PM #8
01-01-2007, 10:45 PM #9
if you use you car as a daily driver 4.10's will heat up especially with freeway driving.. and once they heat up and cool off enough they become brittle ass glass.. and it will happen faster than you think so be careful.. i have 3.73's and they made a hell of a diff. plus 4.10's would make your first gear pretty short but definetly interesting
01-01-2007, 10:55 PM #10
oh btw i jus did a moser 12 on mine..... roughly $2400 cuz i got mine optioned out.and $600-$800 for installation if your not feelin puttin it in.. be ready to do some cutting on you tq arm if its aftermarket.. there are a second set of holes on the rear mount you'll have to switch too but your gonna have to cut the firs set off... and a slight fabrication of new brackets for your sway bar.. and dont expect any mounts for brake lines.. and theres a bracket for your parking brake the is bolted in with the traction bars.. the firs 3/4 inches of the bracket on the inside of trac bar has to be cut so it sits flush.. sorry for the novel but i figured you should know whats comin cuz its not a "direct bolt in".. i learned the hard way
00 SS TRak CAM,VALVETRAIN,CAI,HOOKER LT'S,3" ORY,CAT DELETE,PCV+EGR DELETE,LS6 MAN.90MM PORTED T/B, ASP UNDERDRIVE PULLEY,LS6PORTED OIL PUMP, FULLY BUILT T56 VIPER TRANNY,MOSER 12 BOLT 3.73'S 33 SPLINE BOLT IN AXELS ALL HOTCHKISS SUSPENSION.,BMR ADJ. TQ. ARM.,SFC'S, E. CUTOUT. 423 rwhp 416 rwTQ.
01-02-2007, 04:43 AM #11
01-04-2007, 06:08 PM #12
I went with 4:10's in my WS.6. They made the car a bitch to launch and it would break a set of gears every few months on Nittos. From a roll it was a beast but from a stop they never helped me at all and stickier tires were definately not an option if Nittos were breaking gears. From now on I will never do a gear swap in a 7.5" 10 bolt ever again. Save for the 12 bolt, then get the gears. My buddies with 3:42's and similar mods were consistently faster than me because my car couldn't hook for shit. As for gas mileage I really didn't notice much of a difference. With the 6 speed the gas mileage doesn't suffer much at all.
01-04-2007, 07:48 PM #13
OEM GM 3.42 ring and pinion gears, used
By 2000SSM6 in forum Parts For Sale / TradeReplies: 5Last Post: 07-06-2013, 10:08 AM -
Up grading to 3.73s (ring and pinion?)
By 01camaross in forum DrivetrainReplies: 19Last Post: 02-20-2008, 08:53 AM -
fs: 3:42 ring and pinion
By luch900 in forum Parts For Sale / TradeReplies: 0Last Post: 08-02-2006, 06:57 AM -
Richmond ring and pinion 3.73 NIB
By LUGNUTT in forum Parts For Sale / TradeReplies: 1Last Post: 12-16-2005, 05:14 AM -
Ring and Pinion Gear
By WS6ICK in forum DrivetrainReplies: 4Last Post: 08-05-2005, 08:18 AM
