    Senior Member JoshuaGrooms83's Avatar
    Lake Geneva, WI
    98 Trans Am
    Windows are acting weird!!
    Ok, let me know if you've heard of this one!
    Driver side window... check
    Driver side window rolls down... check
    Driver side auto rolldown.... check
    Driver side roll up..... check
    Passenger window... check
    Passenger side window goes down from driverside control... check
    Passenger side window goes up from driverside control..... NOGO
    Passenger side window goes up from passenger side control.... check
    Passenger side window goes down from passenger side control... NOGO
    WTF?!?!?!?
    For those of you not following...
    I can roll down my passenger side window from the driers side but i cant roll it up from the driver side. I can roll up the passenger side window fromthe passengerside but i cant roll it down from the passengers side.
    Catch that this time? So im lost, any hints
    Member vannatte's Avatar
    Noblesville, IN
    1998 Pontiac Trans Am A4
    I'm not familiar with that problem. Have you checked the connection on the passenger-side switches? If the connection is good, maybe the switch has gone bad.
    Member Z28collection's Avatar
    chapin,s.c.
    black silver
    99 z28, 81 z28
    windows
    i could only think that it is one or both switches bad. i remember reading somewhere that the wire harness for the pass. side window runs off of the drivers side harness and there is some sort of voltage drop between the two and causes the pass. side window to be slow. i dont know if its related but maybe something to look into.
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Pull off the passenger side switch and try making the window go up or down from the drivers side.
    Lake Geneva, WI
    98 Trans Am
    Quote Originally Posted by Z28collection View Post
    now that you mention it! i did notice it use to do that before it went out all together.
    Senior Member
    Jacksonville, FL
    Not your issue but when my passenger side motor died and I replaced it only the passenger side switch worked - replaced the drivers side switch module and was fine.
  1. lt1 acting weird (video)
    By Mike510 in forum LT1
    Last Post: 03-27-2011, 05:36 AM
  2. Help Car is acting weird...
    By MRM 01 in forum Firebird / WS6
    Last Post: 04-15-2010, 02:04 PM
  3. Trip and gauges acting weird
    By GottaHaveLS1 in forum Stereo and Electronics
    Last Post: 01-31-2006, 12:15 PM
  4. Oil needle acting weird.
    By Zeroskater1028 in forum General Help
    Last Post: 11-29-2005, 02:57 PM
  5. blinker switch acting weird
    By myk02k in forum General Help
    Last Post: 10-15-2005, 09:23 AM
