Thread: Help Car is acting weird...
04-14-2010, 08:35 PM #1
I just did the wire mod and the tcs mod and when i finished it up i started the car and it acts as if it loses battery when i switch it in drive also when i give it some gas. I took out the battery when i was doing the mods but idk what it could be??
never mind it road it this morning
and it seemed to be fine
04-15-2010, 04:34 AM #2
no one???? i need help!!!!!!!!!!!!!!
04-15-2010, 06:52 AM #3Senior Member
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
explain the wire mod and tcs mod. never heard of the first one.
04-15-2010, 07:33 AM #4
If you disconnect the battery for a long period of time...the pcm needs to relearn fuel trim etc....so it may take a couple of drive cycles to feel normal again......
04-15-2010, 07:45 AM #5Member
- Jul 2006
- Loveland/Ft. Collins, CO
Blue- 2001 Formula Firehawk
Did you get your battery connectors on good and tight?
04-15-2010, 10:30 AM #6
It's normal for your car to run a little off when you disconnect the battery and then pull the pcm do do the wire mod and tcs relocation mods. The car will go through a short relearning process and be back to normal. Unless you forgot to connect some of the grounds back up or bent a pin hooking the pcm back up to the harness.
04-15-2010, 02:04 PM #7
yea thats it started to act a little better today. thanks guys
lt1 acting weird (video)
By Mike510 in forum LT1Replies: 14Last Post: 03-27-2011, 05:36 AM -
Question: weird acting turn signal
By johnny 5 in forum General HelpReplies: 1Last Post: 02-19-2011, 07:29 AM -
Help: Windows are acting weird!!
By JoshuaGrooms83 in forum Stereo and ElectronicsReplies: 5Last Post: 06-19-2008, 09:40 AM -
Trip and gauges acting weird
By GottaHaveLS1 in forum Stereo and ElectronicsReplies: 1Last Post: 01-31-2006, 12:15 PM -
Oil needle acting weird.
By Zeroskater1028 in forum General HelpReplies: 3Last Post: 11-29-2005, 02:57 PM
