Thread: Rough Idle
06-09-2008, 02:00 PM #1Junior Member
- Apr 2008
- Alamogordo
Black- 2000 TA
Rough Idle
I've got a bit of a problem with my 00 TA 6 speed. I only have a SLP lid and Slp LMII and just recently changed wires, o2 sensors, clutch, pilot bearing, throwout, bell housing seal and rear main seal. I origanally took my car in for a rough idle, and found multiple leaks due to the pilot bearing being destroyed. When I am parked the engine has a idle as a boiling radiator would have. The roughness of the idle is not constant and no internal knocking at all. I can see the tension pulley move everytime that I feel the "boiling" idle. Need help,Any suggestions?
06-09-2008, 03:51 PM #2
maybe one of your plug wires isnt all the way connected. Did you use dielelectric greese in them? moisture could cause misfire too.
06-10-2008, 05:16 AM #3Junior Member
- Apr 2008
- Alamogordo
Black- 2000 TA
Used the grease and all are plugged in correctly, check! Had the engine checked for misfire and there was none recorded for 15 minutes even though the rough idle was happening.
06-10-2008, 03:54 PM #4
maybe a vac hose is leaking? Sounds wierd have you driven it much? my car runs a little rough when its not driven much but clears up
06-13-2008, 08:21 AM #5Junior Member
- Apr 2008
- Alamogordo
Black- 2000 TA
I read a few other threads and saw something about cleaning the MAF and TB. Tried that as well and still have the same idle. I will try to locate a vaccum lead. What is a good way to find out if there are leaking?
06-13-2008, 11:06 AM #6
i havent done it with a fuel injected car but, starting fluid at a vac leak will make the engine rev just slightly. A little goes a long way though.
06-13-2008, 11:35 AM #7
Could be an intake leak also not sure if your year has an egr valve but mine was leaking around there once. It would cause it to run like shit.
06-13-2008, 06:37 PM #8
check the pcv hose for cracks, it runs into the intake on the passenger side. Check the backside of the hose and see if it's cracked.
06-13-2008, 06:49 PM #9My Neighbors Hate Me!!!
- Jun 2006
- Ft. Lee, Virginia
Artic White- 2001 Chevy Camaro SS
You might want to check your spark plugs for cracks in the porcelain. I've heard of this sometimes being the cause of a rough idle/misfire.
Rough Idle
By thacher2189 in forum LT1Replies: 3Last Post: 02-19-2012, 02:04 PM -
Help: Rough Idle
By 1WickedWS6 in forum GM TrucksReplies: 12Last Post: 01-04-2012, 07:16 AM -
Help: intermittant rough idle, off idle hesitation
By Matto4785 in forum General HelpReplies: 1Last Post: 09-21-2009, 05:12 AM -
Help: rough idle
By RLamas in forum Firebird / WS6Replies: 8Last Post: 05-01-2009, 04:59 PM -
C5 Rough Idle
By BlkNBlkC5 in forum CorvetteReplies: 1Last Post: 04-14-2007, 06:42 PM
