Results 1 to 3 of 3
    NW Chitown
    2002 WS6
    I need a replacement venturi tube...
    Hey all-
    I got a racetronix pump and hotwire kit on the boards here a few months back and just got around to starting the install this weekend while the motor is out being worked on.
    Got the tank down and started following the directions... after cutting the old venturi tube off I found out that I didn't have the one that is supposed to come with the pump.
    I had some high pressure rubber tube which I used to see if it would work... but once you bend it as tight as that stock tube is bent it just collapses on itself.
    Any ideas where I can get another venturi tube from?
    Thanks all!
    -Eagle
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Can you just buy some metal fuel line and bend it in the shape you need?
    NW Chitown
    2002 WS6
    Nope... its for the fuel pump assembly in the tank...
  1. Wtf you tube
    By cuervo25_1 in forum Almost Anything Goes
    Last Post: 02-12-2011, 08:19 PM
  2. long tube vs. short tube
    By beer in forum External Engine
    Last Post: 02-12-2009, 02:21 PM
  3. What Tube is this?
    By LIGHTNINGMCQUEEN in forum General Help
    Last Post: 09-21-2008, 08:28 PM
  4. Headers, Long tube vs Mid tube
    By hix5000 in forum External Engine
    Last Post: 05-04-2008, 07:48 AM
  5. AIR tube
    By adham in forum General Help
    Last Post: 04-10-2006, 02:26 PM
