Results 1 to 13 of 13
Thread: AIR tube
04-06-2006, 01:26 PM #1Member
- Sep 2005
- Newport News, VA
Navy Blue Metallic- 2000 Pontiac Trans Am
AIR tube
just changed my AIR tube on the passenger's side because the other was kinked.
the new tube is getting incredibly HOT, it is melting everything close to it
the one on the other side is no where near the temperature of the new one
i wrapped a rubber hose around it so that it does not melt my damn plug wire
does anyone know why this is hapening
PS: the metal air tube does have the protection material that is wrapped around it so its not just the bare naked tube
04-06-2006, 01:55 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
Don't have a clue, you're talking about the metal pipe coming off the exhaust right? There's a gasket between the header/pipe but don't think it would transfer that much heat even without it??? If you need the gasket PN it's 12553617.
04-06-2006, 02:10 PM #3Member
- Sep 2005
- Newport News, VA
yeah thats what im talking about
u may be right because i dont have the gasket
04-06-2006, 02:18 PM #4Senior Member
- Jul 2005
- Jacksonville, FL
They're cheap, had to order some cause the dealer didn't have any in stock when I removed mine for my plug change - just wanted them "in case." If you have to wait on them locally PM me your address and I'll send you one.
04-07-2006, 04:54 PM #5Member
- Virginia Beach, VA
Red- 2000 SS
Could your check valve be shot?
04-08-2006, 08:30 AM #6Senior Member
- Jul 2005
- Jacksonville, FL
When mine clogged it threw code P1416, never checked to see how hot it was getting though.
adham - should be getting the gasked today or Monday for sure, remember to be nice to the air pipe bolts - torque is only 15 lb ft.
04-08-2006, 10:32 AM #7Member
- Sep 2005
- Newport News, VA
ok, thank u very much for all of your help!
04-10-2006, 12:50 PM #8Member
- Tulsa,OK
Quick Silver- 2002 Z06
Sounds to me like the valve is not working and hot exhaust is going into the tube. Thats the only thing it really can be IMO.
04-10-2006, 12:57 PM #9Member
- Sep 2005
- Newport News, VA
"2001NBMZ28" sent me the gasket and i bought a new check valve and everything is working fine
thanks for all the help
04-10-2006, 01:09 PM #10Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
Glad to hear you got your problem fixed.
04-10-2006, 01:21 PM #11Senior Member
- Jul 2005
- Jacksonville, FL
Good deal.
04-10-2006, 01:27 PM #12SleeperZ28Guest
If you have a compressor, some brake clean, and some spare time, you can try cleaning the air valves. I've had my pass side on fail twice, the first time I just shot it with brake clean and put it back and it worked fine for a few months, The second time I cleaned it out with the brake clean, than blew a fairly hard shot of air thought both sides of the valve. I used my hand to make a seal on the end of the tube but a hose would be better. It's been working fine since then. Could have bought a new one, there not that expensive and easy to replace, but I was bored and figured why not. Just thought I'd share that.
04-10-2006, 02:26 PM #13Member
- Sep 2005
- Newport News, VA
my valve was actually broken from the inside
there was a piece that was loose and was rattling like hell
Wtf you tube
By cuervo25_1 in forum Almost Anything GoesReplies: 26Last Post: 02-12-2011, 08:19 PM -
long tube vs. short tube
By beer in forum External EngineReplies: 10Last Post: 02-12-2009, 02:21 PM -
What Tube is this?
By LIGHTNINGMCQUEEN in forum General HelpReplies: 9Last Post: 09-21-2008, 08:28 PM -
Headers, Long tube vs Mid tube
By hix5000 in forum External EngineReplies: 11Last Post: 05-04-2008, 07:48 AM -
Question: LS1 - EGR Tube Mod ?
By 99CANADAHAWK in forum General HelpReplies: 6Last Post: 02-22-2008, 01:46 PM
