Thread: IDLE PROBLEM.... any ideas
06-09-2008, 10:13 AM #1live fast, die young.
- santa ana
metallic blue- 1969 camaro
so ive got a 95 trans am LT1/t56 in a 69 camaro.
The car will start up with no problem. It will also go through first gear and reverse and then back to idle with no problem. But once i take it to second gear or beyond it needs constant gas. If i push the clutch back in to slow down after first gear the car will die on me.
I tried cleaning the IAC, that did me no good. I was wondering if anyone else has encountered this problem? any ideas? any help or ideas are greatly appreciated.
thanks guys
06-09-2008, 04:44 PM #2Senior Member
- Feb 2006
- Orange County, NY
If you slow down are you putting the tranny in neutral and letting off the clutch?
06-09-2008, 07:47 PM #3live fast, die young.
- santa ana
it will die either way.
If i just push in the clutch it will die, or if i put it into neutral and let off the clutch it will also die.
But it will e fine if i do this in first gear or reverse.... its very weird
06-10-2008, 10:00 AM #4Senior Member
- Feb 2006
- Orange County, NY
What rpm is it idling at when you let out the clutch and start to slow down? Do you have a vacuum gauge? Do you have power brakes?
06-10-2008, 10:50 AM #5live fast, die young.
- santa ana
06-10-2008, 11:25 AM #6Senior Member
- Feb 2006
- Orange County, NY
First find out what the idle is at. Mine is at 1000 rpm. When coming to a stop it idles at around 1200 or so. Do you have ac? The old tach should have been electrical too if you have one. I looked at the wiring schematic and it shows a white wire from the pcm that goes to the tach. I am not sure if you will need an adaptor or not to make the tach work. Hook it up first to see what you have. Do you have a light for the check engine?
Cruise control problem.. any ideas? Thanks
By PUNISHERx216 in forum General HelpReplies: 7Last Post: 07-27-2011, 02:31 PM -
Transmission Problem. Any ideas?
By 02convertibleT/A in forum GM TrucksReplies: 25Last Post: 07-30-2010, 07:34 PM -
Idle Problem...any ideas?
By jcso1477 in forum GTOReplies: 24Last Post: 01-30-2010, 07:23 PM -
having idle and decel issues...not sure whats up. any ideas?
By ninobrn99 in forum External EngineReplies: 41Last Post: 05-16-2008, 12:34 AM -
Idle Problem
By larryndog in forum V6Replies: 2Last Post: 08-13-2006, 04:55 PM
