Results 1 to 20 of 42
12-02-2006, 06:13 PM #1Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
having idle and decel issues...not sure whats up. any ideas?
When i start the car cold, it starts up fine. it smells like fuel really bad though. lets say i pull out of my parking spot and its still cold. ill reverse and then put it in first gear and start to go. when i let off, the idle drops to about 1500 and stays there. as it warms up it gets lower and lower until it reaches where it should be, about 950. well i take off and drive for a few seconds. when i let out the clutch, take it out of gear and brake, the rpms dip down to about 250-300 and then climb back up again. it does that for a bit, then will finally stablize after a while. however, when i try to give it more than 60% throttle and shift quickly, i can hear it popping in the exhaust. any thoughts as to what could cause this? it happened after i dyno'd it and has been doing it since. now for the mods:
370 iron block
stock ls6 heads
prc springs
f13 112
pacesetters
tsp catted y
ram clutch
42# injectors
royal purple 10w-30
ngk tr6s
msd 8.5mm wires
ls2 chain
stock oil pump
stock alt.
stock water pump
ls6 intake
stock ported tb
maf in place, but running in sd
o2s are enabled
MTI lid
asp pulley
ive also noticed that there are a few times that im going to turn from a stop and the car sputters and seems like its going to die, but still goes, but barely! no matter how much gas i give it. its happening a bit more often than it did in the past. im thinking maybe its the pulley, but havent had a chance to swap them out to see.
12-02-2006, 06:17 PM #2Senior Member
- Aug 2003
- Honolulu HI
also, ive had my battery and alternator checked and they're both fine. i havent pulled my plugs to check them yet, but ive thought of doing the following:
changing my plugs
wires
intake gaskets
iac sensor
tps sensor
crank pulley
and also the oil. going back to regular oil. i did notice it started happening after the last oil change. not immediately after, but after it.
12-02-2006, 06:36 PM #3Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
Same here, hoping someone knows what the hell is going on. Mine started after cam swap.
12-02-2006, 06:44 PM #4Senior Member
- Aug 2003
- Honolulu HI
pm me a list of all your mods..all of them and whats still stock
12-02-2006, 06:58 PM #5
12-02-2006, 07:09 PM #6Senior Member
- Aug 2003
- Honolulu HI
nope..eh, just post it then.
12-02-2006, 07:13 PM #7Senior Member
- Jul 2005
- Earth
http://www.ls1tech.com/forums/showth...highlight=idle
Above thread from tech site explains it all. LS6 manifold has been removed, it was leaking, but it didn't cure all of my problems. Still dips exactly like yours. Mods:
Volant CAI
TBB
Ported TB
TR224 .563 114 cam
Pacesetter LTs, ORY, and Hooker CB
LS1edit tuning couldn;t get rid of problems
12-02-2006, 07:14 PM #8Senior Member
- Aug 2003
- Honolulu HI
so we have pacesetters and the ls6 intake in common. what springs and stuff?
12-02-2006, 07:20 PM #9Senior Member
- Jul 2005
- Earth
whatever came with the TR224 cam package....seems like everyone keeps thinking it is in the tune. I don't know wof anyone around here with HPTuners, edit can't log the data
12-02-2006, 07:26 PM #10Senior Member
- Aug 2003
- Honolulu HI
well u met up with bill. he knows his shit pretty well. so the fitting in the back of the intake for the vaccum broke? ive been thinking maybe its my intake, but i wasnt sure.
12-02-2006, 07:30 PM #11Senior Member
- Jul 2005
- Earth
Yeah fitting broke, replaced with LS1 intake and it got rid of the major revving problems. But I am still stuck with the decel when I let the gear out, or when I slow down under 10 mph it dips. Bill checked it out pre-LS1 intake install, and since his prices have jumped since he started a website up and all. $600 is the quote on his site for a tune now.
Funny thing I'm over on HPTuners looking for a local guy and I saw your thread looking for a tuner in HI
12-02-2006, 07:33 PM #12Senior Member
- Aug 2003
- Honolulu HI
sad thing is, i dont have my ls1 intake anymore. if the decel is still happening, then its something else on top of that.
12-02-2006, 07:35 PM #13
12-02-2006, 07:37 PM #14Senior Member
- Aug 2003
- Honolulu HI
ive done both and it still happens. at first i thought it was maybe the o2s, but it it happens when its cold, what does that tell ya? its not the o2s
sob!! i just wanted to sell the car and move on
12-02-2006, 07:39 PM #15
12-02-2006, 07:43 PM #16Senior Member
- Aug 2003
- Honolulu HI
haha..i feel ya man. ive thought maybe the oil, but have yet to change it. it has something to do with being hot and cold and idle and decel...but what?! if mike and bill couldnt figure it out, im nervous
12-02-2006, 07:45 PM #17
12-02-2006, 07:46 PM #18
12-02-2006, 07:50 PM #19Senior Member
- Aug 2003
- Honolulu HI
so there goes that. have u changed the plugs or checked them at all? maybe the springs to see if any are broken or binded?
12-02-2006, 07:57 PM #20
idle issues... idle high. unplugged tps runs good?
By okiels1 in forum Firebird / WS6Replies: 2Last Post: 12-31-2016, 03:36 AM -
ws6 idle issues
By 1998 T/A in forum Firebird / WS6Replies: 11Last Post: 05-07-2015, 05:23 PM -
Idle Problem...any ideas?
By jcso1477 in forum GTOReplies: 24Last Post: 01-30-2010, 07:23 PM -
Help: Ls6 in, idle issues
By DemonSpeed in forum General HelpReplies: 5Last Post: 06-26-2008, 01:04 PM -
IDLE PROBLEM.... any ideas
By 69camarokid in forum LT1Replies: 5Last Post: 06-10-2008, 11:25 AM
