Thread: 98 Trans Am Tuner and Fan issue
06-07-2008, 08:39 PM #1Junior Member
- Jun 2008
- Miami, FL
Red- 1998 Trans Am
Diablo Sport and Superchips only make a tuner for 99 LS1 and forward. Does anyone make a tuner for 98. I read the computer is not compatible...Can i just change the computer for one from 99-02? or is it more complicated than that?
My check engine light is on saying either fan 1, wiring or its relay is damaged. Does anyone know when these fans should turn on? 1 then2 or both at the same time?
06-07-2008, 08:45 PM #2
i think they come on both at the same time, i have never actually looked to see if both turn at the same time, if you only got one running then thats probably your problem
06-07-2008, 08:47 PM #3Junior Member
- Jun 2008
- Miami, FL
Red- 1998 Trans Am
Yeah today i noticed i had only one running..my car is not overheating but i dont want to test my luck. I just got the car this week
06-07-2008, 09:09 PM #4Junior Member
- Jun 2008
- Miami, FL
Red- 1998 Trans Am
wow what are the odds.. stang slayer you are in miami and we both have 98s...what have you dont to your ride...tuner?
06-07-2008, 09:20 PM #5
i have yet to get the car tuned, im still deciding whether to go head/cam nitrous or turbo, i should find out monday whether a custom turbo is on my budget.i have lt headers asp crank pulley, texas speed airlid, slp mass air,smoothbellow, ported tb.
06-08-2008, 06:53 AM #6Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
From what I remember one fan runs continueously and the other comes on as the engine reaches higher temperatures or when the A/C is running.
I have a `98 and I run the SLP fan switch. it allows you to run both fans at low speed or both at high speed or leave it off so the computer controls them.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
Temperature Issue 2002 Trans Am WS6
By Zedtwentyeight in forum Firebird / WS6Replies: 4Last Post: 11-07-2011, 06:41 PM -
Is this a trans or a clutch issue?
By dbs1 in forum Manual TransmissionReplies: 9Last Post: 01-29-2010, 02:33 PM -
02 trans am transmission issue
By yffudo in forum Automatic TransmissionReplies: 16Last Post: 10-23-2008, 06:49 AM -
By MR.Dick in forum General HelpReplies: 14Last Post: 06-13-2008, 11:26 AM -
99 Camaro Ls1 Trans. Issue
By h8 ur pony in forum Automatic TransmissionReplies: 2Last Post: 05-01-2006, 11:10 AM
