Thread: High RPM shift problem
06-07-2008, 12:16 PM #1
I went to the track the other day and could not shift into 2nd at high rpms. Someone told me it might be the syncros in the trans. Another said it could be the clutch not being pressed in completely. Anybody have any ideas??
06-08-2008, 07:52 AM #2
anyone have any ideas??
06-08-2008, 10:10 AM #3
Come on guys help a fellow LS1 out.
06-09-2008, 08:20 AM #4Junior Member
- Mar 2008
- Baltimore, MD
sounds like you need to do the "drill mod" do a search and you should find posts about it and a "how to"
06-10-2008, 04:39 AM #5Senior Member
- Apr 2008
- Madison, WI
+1 drill mod
06-10-2008, 01:33 PM #6
06-11-2008, 10:00 AM #7Junior Member
- Jun 2008
- Attleboro, MA
BLACK DEATH- 1999 Supersport M6
Do you have a centerforce pressure plate?
This sounds kooky, I know. But when I bought my car, I had the same problem. The clutch was worn, slave cylinder was old style. Replaced it all with a centerforce DF setup w/stock flywheel and a newer slave. Now this clutch is wearing down and at high rpms the pressure plate is pushing the slave cylinder back just enough to keep full disengagement from happening. I tried bleeding, and the only thing i can do is to shift at 4500 or I can't shift fast. Getting worse too! New clutch and 15lb flywheel in the works, along with new rear end.
Personally, I will never use a centerforce pressure plate again. The counterweights have no way to balance themselves, and this has been a problem with high rpm shifting since about a year after installed.
Also, if it is only in 2nd, sounds like a synchro to me. Do you have an older style t56? They had crappy shift forks, from what I've been told. My t56 is updated, thanks to a fight with 3-4 fork that I won.Last edited by malott442; 06-11-2008 at 10:01 AM. Reason: i'm dumb
06-12-2008, 05:14 AM #8
Thank you to all. I will do the drill mod this weekend and see if that cures the problem.
06-14-2008, 10:58 AM #9
Wow it worked perfectly. Thank you to all.
06-29-2008, 06:59 PM #10
OK i have looked but cant find the drill mod where can i find it????
06-29-2008, 07:13 PM #11Senior Member
- Apr 2008
- Madison, WI
Use this and Skip the steps that involve the McLeod cylinder replacement.
http://www.installuniversity.com/ins...r_cylinder.htm
06-29-2008, 07:19 PM #12
thanks a bunch, i will try this mod before buying a new shifter
high shift points & high idle
By Red 99 T/A in forum General HelpReplies: 5Last Post: 07-26-2010, 09:04 PM -
shift points too high
By LT1 > LS1 in forum Automatic TransmissionReplies: 13Last Post: 06-23-2009, 07:12 AM -
Question: Can't hit 3rd on a high RPM shift with T56
By poc2121 in forum Manual TransmissionReplies: 11Last Post: 05-12-2008, 05:51 AM -
Cant shift at high rpms
By LTLDEV1 in forum Manual TransmissionReplies: 3Last Post: 05-17-2007, 11:22 PM -
2-3 shift problem
By bplazas in forum Automatic TransmissionReplies: 14Last Post: 06-14-2006, 07:24 PM
