    Mascoutah, IL.
    1998, Pontiac Formula
    Question Cant shift at high rpms
    I have a 98 formula and i just got a new centerforce dual friction clutch and a new beefed up tranny and i cant shift at high rpms. And when i say high i mean above 3. I have a updated slave, flywheel, and master cylinder and it still wont shift. it work for a day after i got a new master cylinder but then it got worse. If any1 could help me out that would be great.
    someday joejenkinsglass's Avatar
    Iowa
    green
    98 formula
    be sure the clutch system is bleed all the way I have not had the pleasure of doing that yet heard its a pain also with the weights on the center force the pedal will probably be stiffer as the rpms go up good luck
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    Try the bleeding thing, and good luck. Won't be long till your clutch starts sticking to the floor while you are accelerating. CF () is POS in our cars.
    2002 Formula Firehawk 96z28's Avatar
    San Diego CA
    did you change the t56? why?
  1. Only smokes at high rpms
    By Fine 69 in forum General Help
    Last Post: 01-09-2012, 04:45 PM
  2. Help: High RPMs.
    By 98maro in forum General Help
    Last Post: 03-02-2011, 03:56 PM
  3. cant shift fast in higher rpms
    By Darkrider02 in forum Manual Transmission
    Last Post: 09-24-2010, 11:28 AM
  4. RPMs too high
    By Shudson105 in forum Automatic Transmission
    Last Post: 10-07-2009, 05:43 AM
  5. Help!! High idle rpms
    By degenerate in forum General Help
    Last Post: 04-20-2007, 05:32 AM
