Results 1 to 14 of 14
Thread: blinking SES code
06-04-2008, 03:59 PM #1Member
- Aug 2006
- Madrid, Iowa
red- 02 trans am ws6
blinking SES code
I went for a ride the other day and had to cross a puddle of water that covered the road, (I was on a one way street, no other option). I went thru it slowly, and must have got something wet because now I'm throwing a blinking SES code. I was told it ment there is a misfire, I changed the plugs and it's still doing it. Just wondering what I might of got wet or where to start looking, Thanks,B
06-04-2008, 05:39 PM #2Senior Member
- Apr 2008
- Madison, WI
yeah the blinking SES is a misfire. Usually the plug wires and coils get wet and cause the misfires. It may go away if it dries out. Otherwise try a good set of plug wires
06-04-2008, 07:30 PM #3Member
- Aug 2006
- Madrid, Iowa
I have the msd wires. are you thinking it could only be linked to coil/plug/wires? That would narrow it down. Thanks
06-04-2008, 07:33 PM #4Junior Member
- Jan 2008
- columbus, ohio
black- 1999 T/A
i thought that a blinking light meant catalyst damage that may or may not be a misfire.
1999 Trans Am, BBK SSI, magnaflow, MSD Wires, Tr55, Pro 5.0 shifter, centerforce clutch, hotchis sfc, kyb's, slp lid and bellows, pacesetter lt, ory and a noisy rear end.
06-04-2008, 07:51 PM #5
06-04-2008, 08:38 PM #6
blinking SES is misfire.
06-05-2008, 03:06 AM #7Senior Member
- Apr 2008
- Madison, WI
Yeah a blinking SES indicates a catalyst damaging misfire.
06-05-2008, 03:08 AM #8
06-05-2008, 04:05 AM #9
if the pcm thinks your engine is gonna send raw fuel into the exhaust therefor damaging your cats it will throw a blinking SES code to tell you to hurry the hell up and fix it, throw a scan tool on it to see if you can narrow it down to a particular cylinder. its prolly a random misfire tho, infamous p0300
06-05-2008, 05:38 PM #10Member
- Aug 2006
- Madrid, Iowa
I was thinking 02s since that should have ben all that got wet. I have no cats. It does have a exhaust pop every once in awhile.
06-05-2008, 05:53 PM #11Senior Member
- Apr 2008
- Madison, WI
Go get the code read.
06-06-2008, 08:49 PM #12Member
- Aug 2006
- Madrid, Iowa
Read the code it was a p300, a MAP sensor code, and a 1133 or something. the 1133 was an 02 sensor code. I have ben throwing the MAP code for awhile and I tracked that down to a bad ground. the 02 code came from a bad sensor on the pass. side that was dented pretty good (car is lowered 2 1/2 inches and the tubular kmember lowered it another inch) I think I picked up a rock somewhere. Swapped the 02 out a the car runs good again. No codes. Thanks to all that helped, B...
06-06-2008, 09:27 PM #13
06-07-2008, 08:36 PM #14Member
- Aug 2006
- Madrid, Iowa
Correct, I worded it wrong, it was a p300(misfire code) also a MAP code and a 02 code. Thanks again for all the help. Heading to Cordova ILL for a track tune Saturday nite. Just if anyone out there that wants to meet up.
SES Light Blinking
By lvbroham1 in forum Computer & TuningReplies: 4Last Post: 11-25-2008, 06:47 PM -
Sloooooow Blinking Blinker
By MikeSomething in forum General HelpReplies: 10Last Post: 03-21-2008, 05:38 PM -
Help: Auto Blinking and Dimming!!!!?
By matthewaqui in forum Firebird / WS6Replies: 0Last Post: 02-20-2008, 07:08 AM -
Blinking LED on my tranny?
By AirMarcus in forum Manual TransmissionReplies: 6Last Post: 01-25-2007, 08:21 AM -
blinking lights
By phoenix99ta in forum General HelpReplies: 0Last Post: 11-19-2005, 05:55 PM
