Results 1 to 11 of 11
    Impounded MikeSomething's Avatar
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Question Sloooooow Blinking Blinker
    I throw my blinker on in either direction and it blinks so freakin slow compared almost EVERY car out on the road. I have a 2000 Z28 and was wondering if this is just a general GM fault in these cars or that I need to adjust it or put a fix on it...Help me out, thanks!
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Look at your voltage gauge-I'm betting you have a high voltage or overcharge-or maybe a low voltage and undercharge-it depends on the circuit. Not sure what these f-bodies would do,try revving the engine and see if it changes speed of blink or voltage level.It could be as simple as the flasher going bad also-try changing that,it'll only cost a couple bucks at Auto dummy. I just bought some cool electronic flashers that have a constant rate of flash no matter what the load,they cost about $9 a piece for you big spenders, also at AZ.
    Senior Member predator's Avatar
    Little Rock, Arkansas
    1966 Corvette Coupe
    prolly had heavy duty blinkers in it... that way if you hook up a trailor it the blinkers dont go nuts on you...
    Mine are the same way.
    I just figured something had to be slow.
    Lowered, HID's, tinted.
    Member Shpoone's Avatar
    Northglenn, Colorado
    Black/Gold....Now Sold...
    10th Anny. Firehawk #001
    Mine slows down or even stops when the blinker portion of the light burns out. These aren't the best sealed connections for lights I've even seen...
    Have you gotten out and checked to make sure they're working? Just a suggestion based on what happens with mine.
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Quote Originally Posted by Shpoone
    Yea I know what ya mean. On my car if one bulb goes out, it won't flash at all... I'm probably gonna make an attempt at replacing the flasher. Seems like when I fix one thing (The trunk latch) I got 3 more projects.
    Houston, Texas
    2000 C5 Torch Red
    Sorry about the dumb question but wth is the signal flasher. I started taking the knee bolster apart and chiltons says that it's right there. Am I blind?
    Wow.
    Didn't realize this thread was so old.
    Mine has since gone out. I replaced the flasher, all better.
    Flasher is under the dash on the driver's side. Near the radio.
    Houston, Texas
    2000 C5 Torch Red
    yeah. lol... I found another post of yours shortly after that gave away the location. That damn thing was hiding. Chilton's guide said it was to the left of the steering column.
    Thanks Luos. Switched out those front blinkers with some nice LED's. They'll never get hot and melt my bulb housing again.
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    killin me
    Junior Member 99CANADAHAWK's Avatar
    GTA Ontario Canada
    1999 Trans Am FIREHAWK
    I thought it was normal until it happend to mine too ( it actualy blew and I had just bought the car last summer ) shortly after I was comming back from an F-Body show in the summer just as it started to rain verry hard , just re-placed the flasher .
    1999 T/A FIREHAWK - SLP Lid & Bellow,LT`s & Catted Y & Power-Flo Catback , MSD & NGK , UMI 3P SFC,ADJ PHB,STB,LCA`s & Relos , Eibach Pro Kit , Bilstine/SLP Shocks , MAC Diff Cover , BFG & OE Wheels C5DD 18x9.5/10.5 , HID 8000K Headlights - Dyno`d @ 319.07 HP & 327.23 Ft-lb ( Tuned by Champ Motors )
  1. Blinking radio display
    By johnfin in forum Firebird / WS6
    Last Post: 07-13-2013, 09:16 AM
  2. SES Light Blinking
    By lvbroham1 in forum Computer & Tuning
    Last Post: 11-25-2008, 06:47 PM
  3. Help: blinking SES code
    By badazta in forum General Help
    Last Post: 06-07-2008, 08:36 PM
  4. Blinking LED on my tranny?
    By AirMarcus in forum Manual Transmission
    Last Post: 01-25-2007, 08:21 AM
  5. blinking lights
    By phoenix99ta in forum General Help
    Last Post: 11-19-2005, 05:55 PM
