Results 1 to 17 of 17
    Junior Member jpn8801's Avatar
    SoCal
    2000 Trans Am WS.6
    2000 T/A Ws.6 Squeeking bad!!!
    Hello all, I have a 2000 T/A WS.6 & everytime i go over speed bumbs (little or small) back out of a driveway It squeeks in the rear REALLY bad!!! WHat is it? How can I fix it?
    Dcdrummer LS1buckey's Avatar
    Delaware, Ohio
    pewter
    1999 Pontiac Trans Am
    Check your shocks and springs.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Lower control arm bushings???
    Member svt_eater's Avatar
    Ontario, Canada
    2002 Firehawk
    Definitely bushings.
    Jun 2006
    USA
    2001 WS6, 2003 SRT4(sold)
    Bushing! Get it lubed. I had a god awful metal-on-metal sounding screech from my rear that was actually a dried out bushing.
    Delaware, Ohio
    pewter
    I was thinking, not sure how many people have had this problem but I had a real bad squeaking coming from the back of my car and it turned out to be the tail lights. The plastic wing nuts were loose and the rubber washers on the back of the tail lamp were squeaking.
    Just thought I'd throw that in as a possibility
    SAN FRAN SISCO BABY
    VW BEETLE W/ FLOWER
    88 CRX
    mine has the same problem with squeaking
    Ontario, Canada
    yellow
    02 Collector Trans Am
    the bushings need to be replaced. Lube wont cure it.
    Beaver Dam KY
    79 T/A -91 Firebird
    Go visit one of our sponsors and buy some nice pretty new ones!
    Delaware, Ohio
    pewter
    How does every one know for sure it's the bushings? That's not the only thing that can squeek.
    Jun 2006
    USA
    True, but such is the perils of online troubleshooting
    Delaware, Ohio
    pewter
    True true, good point.
    Member sfletch2000's Avatar
    Feb 2007
    Bakersfield, CA
    86 Buick Grand National
    02 WS6-M6 407 RWHP
    i just spray some white lithium grease that comes in a can around the control arm bushings and pan hard bushings. It'll last for a month or two before you have to do it again
    could also be the sway arm bushings...
    Quote Originally Posted by sfletch2000 View Post
    they are cheap to replace...
    Junior Member jimmyjones's Avatar
    Feb 2007
    San Diego
    SOM
    2002 WS6
    Ive got the same problem that has been driving me crazy!
    Pony Killer Insert's Avatar
    Mississauga, Ontario, Canada
    2002 Camaro SS M6
    well... some of your camaro brethren had the same problem... hope this helps.
    http://www.ls1.com/forums/showthread.php?t=88058
  1. What the F##K is squeeking?!?
    By Raoul-Duke in forum Suspension and Handling
    Last Post: 07-25-2009, 09:22 PM
  2. Pulley squeeking
    By rajiv1998 in forum General Help
    Last Post: 09-17-2008, 11:35 AM
  3. Squeeking!
    By sk8ters501 in forum General Help
    Last Post: 12-28-2007, 05:13 AM
  4. Brakes Squeeking!
    By zul8r2002 in forum General Help
    Last Post: 08-06-2006, 10:36 AM
  5. Strange squeeking
    By Transamws686 in forum Suspension and Handling
    Last Post: 07-24-2006, 08:35 PM
