Thread: Strange squeeking
07-21-2006, 12:31 PM #1Junior Member
- Hillsdale Nj
Chameleon- 1998 Trans am
Strange squeeking
Hey guys my friend did me a favor and installed my mosser 12 bolt for me, problem is now the suspension is squeeking to hell. He thought it was maybe a bushing gor folded when he put the suspension back or the spring gringind on its mount.
I hear the noise when ever I hit a bump or if the road is paved unevenly. Also if I push the car down on the rear it will squeek. Please help I have no idea and it is driving me crazy.
Thanks
Eric
07-22-2006, 07:48 PM #2
just fixed a similar problem that was coming from the pass side of my car, it sounded liek a rubber squeak, just put a wrench on everything ex panhard bar shock mounts etc and tighten them up and give it all a good lube, that should fix it if not you missed something or something is worn out or broken
07-22-2006, 07:48 PM #3
kind of a general answer but thats all one can say without hearing it u know
07-22-2006, 07:48 PM #4
sounds like the exact problem i had
07-22-2006, 07:49 PM #5
the shop that did all my work did the above, and fixed it on friday so tahts my advice
07-24-2006, 08:35 PM #6
Sounds like a bushing to me. You'll have to get under it and isolate it. Have someone push on the car and see if you can find it that way. What I've done in the past that I probably wouldn't recommend but does work if you're by yourself in a pinch is to spray one bushing at a time with wd-40 and then push on the car until it doesn't make any noise. At least then you've found the culprit.
What the F##K is squeeking?!?
By Raoul-Duke in forum Suspension and HandlingReplies: 20Last Post: 07-25-2009, 09:22 PM -
Pulley squeeking
By rajiv1998 in forum General HelpReplies: 1Last Post: 09-17-2008, 11:35 AM -
Squeeking!
By sk8ters501 in forum General HelpReplies: 3Last Post: 12-28-2007, 05:13 AM -
Squeeking suspension
By Transamws686 in forum Eastern MembersReplies: 1Last Post: 08-10-2006, 03:43 PM -
Brakes Squeeking!
By zul8r2002 in forum General HelpReplies: 5Last Post: 08-06-2006, 10:36 AM
