Thread: help! trans will not shift
05-30-2008, 07:32 PM #1
i just up graded my stall from a 3600 to a 4000, now my speedometer will not work and my trans will not shift! i have checked the big conn on the side of the trans and the small one on the tail shaft about 3 times. and i check all the fuses. need help asap, please!
05-30-2008, 09:20 PM #2
umm why such inane stall speed? What mods are done to the car, for stall that high you would need some serious work under the hood and really steep gearing.
My, unedcated guess is that the stall speed is just to high for the tranny to work right. Other wise check all the wiring front to back for pinched wires. If all else fails put your old stall back in and see what happens.
05-31-2008, 04:00 AM #3
05-31-2008, 06:38 AM #4
Well, I still think that for mods given a 4000 stall is bit high given the mods you have are a bit high, but thats just me.
I think the first place to start would be to check line pressure and make sure your pump is still working, if that seems fine and all electrics check out then something inside let go. Stock tranny? Running a aux cooler?
If running a stock tranny with no cooler with that stall, you most likely cooked it pretty good on the inside.
05-31-2008, 07:16 AM #5
i have a b&m trans cooler, i was told that i need to start with the speedometer, because if the vss is not working then it wont let the trans shift, the vss looks ok, i have checked the wires and dont see any problems there, i have been trying the find a wire diagram for the vss to the speedometer? any help?
05-31-2008, 07:51 AM #6
I do but no way to post them up. How ever I do have somethings for you to check get a multi meter and measure the ohm readings between the pins (1377-3355 ohms) if that checks out, block on wheel from turning and spin the other, should get an AC voltage reading of 0.5V or so.
Going off what the 2000 manual says.
05-31-2008, 02:45 PM #7
it was the vss sensor i replaced it now every thing works! thanks!
A4 trans wont shift
By Bad Co. in forum Automatic TransmissionReplies: 4Last Post: 07-04-2010, 02:11 PM -
Trans go shift kit
By Itllrun in forum Automatic TransmissionReplies: 4Last Post: 09-28-2009, 08:03 AM -
Question: shift kit good or bad trans go
By SSMOKEshow in forum Automatic TransmissionReplies: 24Last Post: 05-27-2008, 12:10 PM -
Shift kit and Trans Pak for K2500
By Tyler_LS1 in forum GM TrucksReplies: 3Last Post: 11-02-2006, 05:30 PM -
C6 Paddle shift trans.
By C6 Twin Turbo in forum CorvetteReplies: 4Last Post: 09-07-2006, 04:01 PM
