Thread: A4 trans wont shift
06-30-2010, 08:18 PM #1
A4 trans wont shift
I have a 99 t/a with the a4. Nothing major done mild heads, cam. When im on a pass, or just getting in it on a country road it doesnt want to shift from 3rd to 4th. I will hit the rev limiter everytime. I do have a B&M shift pak plus. It a electronic shift kit that ups the line pressure in the trans. I took it off and still no difference. Possible valvebody issues? The trans has only 94K miles on it and has seen the shift kit since new.
07-01-2010, 04:27 AM #2
The shift points need changed in the ecm. Do you have a programmer ?
07-02-2010, 06:20 AM #3
I do not and my local tuner says its the trans. Possible valvebody issues. I have asked him to go through the ecm.
07-02-2010, 11:22 AM #4
does it go into 2nd okay? it does sound like valve body issues, unless it doesnt go into 2nd. then its the 2-4 band that is burned up
07-04-2010, 02:11 PM #5
Mine did that in just about every gear before it took a crap. You need to see what the actual line pressure is and see if it falls on it's face before it is supossed to shift.
Help: my A4 wont down shift. Why
By mglangley21 in forum Automatic TransmissionReplies: 7Last Post: 03-27-2012, 08:37 AM -
wont shift!!!
By tangkiller_z28 in forum General HelpReplies: 0Last Post: 02-03-2011, 10:52 AM -
new trans wont shift
By NEXSTAR7 in forum Automatic TransmissionReplies: 9Last Post: 07-21-2010, 04:51 PM -
SHIFT HAPPENS...you wont believe this
By 02cetransam in forum Almost Anything GoesReplies: 13Last Post: 08-29-2007, 12:57 AM -
wont shift!!
By z28jerad in forum Computer & TuningReplies: 0Last Post: 08-21-2006, 05:35 PM
