Thread: rack and pinion
05-29-2008, 11:54 AM #1Junior Member
- May 2008
- Anaheim
Blue- 1999 Camaro Z28
rack and pinion
ok the boot is leaking. Is there supposed to be power steering fluid in there? Do i have to replace the whole rack?
05-30-2008, 12:44 PM #2
fluid is not supposed to be in the boots. replacing the rack is in order. you might can get a seal kit.
06-02-2008, 01:36 AM #3
Yeah.... I've got the same problem... best bet is to replace the rack... or you can get a seal kit like MRR said... but the best bet is just to replace it... about 120ish for the part... but I don't know how much labor is... (I do all my work myself).... plus you'll have to get an alignment...
06-02-2008, 03:05 AM #4
yep. It's time to replace the rack and pinion steering assembly. Been there.
06-02-2008, 10:47 AM #5Junior Member
- May 2008
- Anaheim
no luck on the seal.. so i guess new rack. cant be that hard to replace.
thanks all for your help
Rack & Pinion
By camaro_convert in forum Suspension and HandlingReplies: 5Last Post: 08-11-2010, 06:55 AM -
LT1/LS1 rack & pinion
By Chad97SS in forum LT1Replies: 5Last Post: 05-03-2009, 07:46 AM -
rack & pinion
By RLamas in forum Firebird / WS6Replies: 10Last Post: 05-17-2008, 06:37 PM -
Rack and Pinion WTF???
By lvbroham1 in forum General HelpReplies: 6Last Post: 07-07-2006, 06:11 PM -
Rack & Pinion
By OneFine99TA in forum DrivetrainReplies: 2Last Post: 03-16-2006, 09:29 AM
