Thread: Rack & Pinion
05-19-2010, 06:31 PM #1
Rack & Pinion
Ok folks, thanks for the kind words of welcome. I've got an insane schedule so checking in is somewhat sporadic. I've got the 02 SS and it's been through the mill. One of the minor and major things that need fixed is the left side return line on the rack & pinion. GM says they don't make one of the two return lines any longer. Go figure. Anyone have this difficulty. This thing handles like a hay wagon without the power steering. Any help would be greatly appreciated.
05-19-2010, 06:34 PM #2
Try your local auto parts store (Advance, Autozone, Napa), they should have the lines in stock.
06-01-2010, 12:12 AM #3Senior Member
- Jan 2010
- texas
silver- 2000 formula
seems any hydraulic hose place could fab you up some
06-01-2010, 03:16 PM #4Junior Member
- Jun 2010
- Albuquerque, NM
White/Blue 30th colors- 1999 30th Trans Am
Rack Line
WOW.....that’s too bad that GM does not make it anymore. I would go down to your local auto parts store and see if you can find a line you can have bent to fit the shape of the GM line. I know most places sell straight pieces of line in different sizes. You just need to get one long enough and then bend it to the right fit. Auto parts stores also sell aluminum line bender tools to bend trans lines and other lines such as this with. This might be an option to look into. You can try some online parts sites as well. Hope this helps.
R-
08-07-2010, 10:53 AM #5
i found the same problem. what im planning to do is cut the hose after the fitting & add a power sterering filter then add a second peice of hose leading back to the pump. hope it works
08-11-2010, 06:55 AM #6
It's a return line. After it leves the rack the pressure drops. You can cut the hard line and have the end flared and replace the hose and use a regular clamp. no need for a special order custom hose. Only on the high pressure side would you need that.
LT1/LS1 rack & pinion
By Chad97SS in forum LT1Replies: 5Last Post: 05-03-2009, 07:46 AM -
Question: Rack and Pinion
By JoshieDoom in forum Suspension and HandlingReplies: 3Last Post: 01-04-2009, 08:04 PM -
rack & pinion
By RLamas in forum Firebird / WS6Replies: 10Last Post: 05-17-2008, 06:37 PM -
Rack and Pinion WTF???
By lvbroham1 in forum General HelpReplies: 6Last Post: 07-07-2006, 06:11 PM -
Rack & Pinion
By OneFine99TA in forum DrivetrainReplies: 2Last Post: 03-16-2006, 09:29 AM
