    Import Killer camarostripes96's Avatar
    Aug 2006
    academy,tx
    1996 Trans am
    Firing order maybe ?? HELP
    ok well i was taking spark plug wires off trying to solve a problem , and now the car is missing really bad and will not start up, well i will but it will die soon, maybe i got the spark plug wires mixed up , does anyone have a diagram on which spark plug wire goes on the opti and on the spark plug?
    Aug 2006
    Missouri
    94 Camaro Z28
    Hope this helps.
    Aug 2006
    academy,tx
    1996 Trans am
    yeh i got that done already and everything is correct
    Aug 2006
    academy,tx
    1996 Trans am
    ok i do have spark at the spark plugs i tested them with a spark tester!!!! what do yall think it can be? my car is on jack stands in the front , so the front is sticking up and my gas gauge says it has little under 1/2 of tank of gas...so what do yall think it could be? its trying to start and if i give it some gas it tries to crank even more...i dont have a clue and i am getting fn pissed at this car!!!
    Senior Member 440 rwhp trans am's Avatar
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    Quote Originally Posted by camarostripes96 View Post
    when you said you were messing aroung in the bay. what did you do. be exact! any water?
    Junior Member epmedia's Avatar
    May 2008
    Spring Valley, CA
    Grey?
    78 BMW 320i with mods
    Ignition-miss, simple no-tool test
    If you got as far as messing with the plug wires, you may as well change the spark plugs. There are a couple of simple tests that can be performed on the ignition system without any tools : 1) carefully listen for spark noises when the engine is idling. 2) "safely" run the engine when it is dark outside and "safely" look for sparks. BE SAFE IN THERE!
    Aug 2006
    academy,tx
    1996 Trans am
    got it fixed she is running BAD A$$ now
  1. Firing order swap
    By blackbear10 in forum Computer & Tuning
    Last Post: 01-18-2017, 06:49 PM
  2. firing order
    By juxi in forum Almost Anything Goes
    Last Post: 02-26-2008, 03:59 PM
  3. Firing Order Swap?
    By Mr Z in forum General Help
    Last Post: 09-22-2007, 08:09 PM
  4. need firing order asap
    By jimbeans in forum General Help
    Last Post: 06-23-2007, 06:14 PM
  5. firing order help please...
    By DrMilhouse in forum Internal Engine
    Last Post: 04-17-2006, 10:50 AM
