Results 1 to 3 of 3
    Colorado
    99 Z28
    firing order help please...
    Hi,
    I'm missing a lot on #1 and #6.
    As I'm standing at the front of the car, which of the two cylinders is this?
    I'm starting by replacing coil packs for 1 and 6, anyone else have any suggestions as to why I'm missing?
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    Dr. M,
    Facing the car, Cylinder #1 is closest to you on the right (drivers side). Cylinder #6 is on the passenger side and is second from the rear.
    Do you have any codes besides misfires?
    Could be many things...spark plugs, wires, coil packs, injectors, etc. Replacing everything could be costly - I would start by moving components around to other cylinders and seeing if the misfire moves too...for example put #1's spark plug to #3. And then the wire. Then the coil pack. Then the injector etc.
    Colorado
    99 Z28
    Thanks Kelli, that was really the only code it was throwing except one security code from a long time ago (probably a misread on the key or something?).
    I'll try moving the coil pack and plug individually from one to another spot and see what happens.
    Thanks for the help.
  1. Firing order swap
    By blackbear10 in forum Computer & Tuning
    Last Post: 01-18-2017, 06:49 PM
  2. Firing order maybe ?? HELP
    By camarostripes96 in forum LT1
    Last Post: 05-26-2008, 03:23 PM
  3. firing order
    By juxi in forum Almost Anything Goes
    Last Post: 02-26-2008, 03:59 PM
  4. Firing Order Swap?
    By Mr Z in forum General Help
    Last Post: 09-22-2007, 08:09 PM
  5. need firing order asap
    By jimbeans in forum General Help
    Last Post: 06-23-2007, 06:14 PM
