    canada
    95 trans am
    Help with roller rockers please
    Hi guys/girls I have a 95 Lt1 with stock cam and am looking for some roller rockers should I go with the 1.6 or 1.7 and which ones I 've been told they are just bolt ins and easy and do I need taller valve covers if so where can I get some I haven't been able to find any tall ones for LT1's thank you for all the help in the past and future
    Simpsons Did it!! 98formy's Avatar
    Minnesota
    83 Z28 new project
    98 Formula WS7-sold:(
    I just finished doing some 1.6 comps with canton valve covers when I did the heads/cam. Summit has all the stuff. One thing though, I was not impressed with the canton covers. I had the make a major dent in the cover and grind away at the alternator some to allow for clearance for the alternator. Other than that, they look really good in the car.The rockers are easy to do, just make sure the lash is set correctly.
    canada
    95 trans am
    thank you for the feedback! Do you have any idea with which ones I should go with 1.6/1.7's cause i am not planning on changing my cam?
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    I would go with the 1.6 rockers. You are going to gain about .030 of lift and the added power of reduced friction.
    If you go with the 1.6 roller tips you can keep your stock valve covers. We also glue and stack valve cover gaskets to gain clearance without everyone noticing..........
    Minnesota
    83 Z28 new project
    The 1.7's should be ok then, but I would stick with the 1.6's though.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Yeah I would just be scared of the POS stock springs.
    How many miles are on the LT1 anyways?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    stock ratio is 1.5. the LT4 motor had 1.6 full roller rockers from the factory with stock covers. also a good set of valve springs are in order to handle the added lift.
    Junior Member 97_lt1_stang_stomper's Avatar
    May 2008
    West Texas
    1997 trans am ws6
    just go with 1.6 rockers check thunder for covers
  1. prw roller rockers?
    By JROBINSON1016 in forum Internal Engine
    Last Post: 09-15-2013, 07:27 AM
  2. roller rockers
    By the_formula in forum Internal Engine
    Last Post: 05-09-2008, 09:11 PM
  3. Roller Lifters and Aluminum Roller Rockers
    By MadSeason in forum Internal Engine
    Last Post: 03-14-2006, 02:23 PM
  4. anyone have the 1:8.5 roller rockers?......
    By 5 ltr. beater in forum Internal Engine
    Last Post: 03-06-2006, 06:12 AM
  5. roller rockers
    By lilicedout24 in forum Internal Engine
    Last Post: 12-15-2005, 08:17 AM
