    N/A nitrously aspirated stangslayer98's Avatar
    miami,fl
    1998 trans am
    weight difference between vert and t-top
    maybe this has been discussed before but ill ask again what are the weight difference between a t-top and vert t/a
    Around 200 pounds IIRC.
    Painted manta stripe
    miami,fl
    1998 trans am
    thats good closer than i thought
    Make real real sure Johns00Z28's Avatar
    Germantown, MD
    2000 Z-28
    So would a hard top be ligher yet?
    Member Z ROADSTER's Avatar
    Shreveport,Louisiana .USA
    PEWTER
    2002 Z/28 VERT.
    I believe its closer to 200 lbs. difference between the coupe vs. the convertible . The difference between the convertible vs. the t-top car is much much closer to being the same curb weight .
    Germantown, MD
    2000 Z-28
    Found this site, look at the bottom, it gives the curb weights. Looks like it's more like a 100lb difference between the two.
    http://media.gm.com/division/canada/...0Firebird.html
    PEWTER
    2002 Z/28 VERT.
    Quote Originally Posted by Johns00Z28 View Post
    COOL ! & SWEET !
    Arizona
    There really isn't much of a difference, and in some cases we have personally seen a couple of T-top cars that came in a little heavier than a pair of verts that I have.
    Been over this before in detail,,,,so several months back I called a couple of friends to meet me at the scale.
    I have a pair of verts, one weighs 3,550 lbs. and the other weighs 3,620 lbs.
    One of the T-top cars at the scales that day actually tipped in slightly heavier than both of my verts at 3,7XX lbs. (can't remember the exact number now) But it had us scratching our heads
    Fact is you can't go by what others have said, or by curb weights posted by manufactures etc....The only way to know for sure is to put your individual car on the scales, get a group of buddies together as I did and compare cars that way,,,you may find some interesting results.
  1. weight difference...
    By camarospade in forum Camaro / SS
    Last Post: 03-04-2010, 10:37 PM
  2. So much for the camaro weight.. New Mustang Weight
    By Aetos in forum Almost Anything Goes
    Last Post: 12-01-2009, 08:07 AM
  3. Weight difference between axles
    By JwMonE99 in forum Suspension and Handling
    Last Post: 02-28-2009, 03:54 PM
  4. weight difference?
    By 8secpumpgas in forum Convertible
    Last Post: 03-28-2007, 06:02 PM
  5. Replies: 3
    Last Post: 02-28-2006, 06:14 PM
