    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Weight difference between axles
    I am upgrading to a moser 12 bolt.
    With the 4.10 gears and detriot locker.
    How much extra weight am I looking to add?
    Also the 10 bolt is a 7.5 inch, what is the 12 bolt "inch" size?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    12 bolt is 8.875".
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    How much heavier is it over the 10 bolt?
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    No one knows how much a 12 bolt or a 10 bolt weights?
    Junior Member Paul Huryk's Avatar
    Sep 2008
    NJ
    Blue
    1984 Camaro
    About 40lbs... Strange 12 bolt to a stock 10 bolt.
    Member ProwlerZ's Avatar
    Myrtle Beach
    2002 Z28
    It will pull about .5" off your 1/4 mile time. There's a moderate weight difference, and a huuuge rotational mass difference. I understand the idea of upgrading the rear as planning for a future build, but you're about 200rwhp away from needing it, and you'd be better off building a 10 bolt. Just my .02
    Sep 2008
    NJ
    Blue
    1984 Camaro
    Quote Originally Posted by ProwlerZ View Post
    The rotating assembly is only a few lbs heavier than the 10 bolt, the unsprung weight is 40lbs heavier - two different things.
    When i did back to back testing at the track, there was zero difference in times and mph that I ran. 3.42 10 bolt vs. 3.42 12 bolt.
    I think it was Car Craft a few months back that had a good axle comparison article. Best recollection is that they had a 9", a 12 bolt, and an aftermarket axle. As I recall, axle weights were listed, but it primarily focused on the horsepower differences which resulted due to the pinion offset from the ring gear centerline. Interesting article...
    Member Bouvers's Avatar
    Blue 1997 Trans Am(Sold)
    Pewter 2001 Trans Am Vert
    I plan to offset the extra weight of a rearaxle upgrade with gearing...
  1. weight difference...
    By camarospade in forum Camaro / SS
    Last Post: 03-04-2010, 10:37 PM
  2. So much for the camaro weight.. New Mustang Weight
    By Aetos in forum Almost Anything Goes
    Last Post: 12-01-2009, 08:07 AM
  3. weight difference between vert and t-top
    By stangslayer98 in forum Convertible
    Last Post: 05-19-2008, 06:12 AM
  4. weight difference?
    By 8secpumpgas in forum Convertible
    Last Post: 03-28-2007, 06:02 PM
  5. Replies: 3
    Last Post: 02-28-2006, 06:14 PM
