Results 1 to 18 of 18
    Junior Member mudnyeri's Avatar
    Ether N.C.
    2001 Trans Am
    Whats The Best Clutch Upgrade??
    2001 Ta Going To Need A Clutch Any Exp. With The Best To Use?? A Few Mods And 150 Shot But More On The Way.
    spec 3+ if you're looking for a track worthy clutch with some street ability. or just the spec 3 if you don't mind a little jiggle in the body [only the 3+ is considered "street-slippable" but it still chatters a SHIT load] Consider an aluminum fly wheel for a quicker rev or a steel flywheel for cost benefits, either way, you'll need a new fly. You'll be in the $800-$1000 range with install
    I would NOT recommend centerforce-mine feels like 2 pillows and is less than 7k miles on it.
    Member blackls1ta's Avatar
    kittanning,pa
    2000 ws.6 m6
    ls7 clutch and ls2 steel flywheel works great
    Ether N.C.
    2001 Trans Am
    Quote Originally Posted by blackls1ta View Post
    steel rather than an alum. flywheel??
    Member chieftransam's Avatar
    Germany
    Blue
    2001 Pontiac Trans Am M6
    +2 for the ls7 clutch and ls2 flywheel
    Senior Member Bottesini's Avatar
    Denton, Texas soon Lafayette, Louisiana
    Blue
    2002 Z28 Camaro M6
    Just put a Ram clutch in mine and so far it is great, but I have not gotten much time to drive it.
    Aug 2000
    Indy
    I'd stick w GM myself..
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    Junior Member jc99ls1ss's Avatar
    Louisiana
    Bright Red
    1999 Camaro SS
    textralia oz700 x grip if you street drive z grip if you plan on trashing on it. z is good for 700 and x for 550 to 600. Cost 1,110 for everything(new bolts, slave,disc,pp,fly) both are same price.
    Blue
    2002 Z28 Camaro M6
    Quote Originally Posted by Danger731 View Post
    Depends mostly to me on what you are planning to do with it. If you have plans to mostly daily drive your car and are close to the 500 flywheel HP range then the LS7 clutch should be a good choice. If you plan on abusing it with sticky tires then an aftermarket is most likely the better route.
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    i have a centerforce dfx and love it i have no problem with it and i have 10k on it and its sweet ball bering pp and 6 puck disk that is still super street able and can handle 600 hp or so
    kittanning,pa
    2000 ws.6 m6
    Quote Originally Posted by mudnyeri View Post
    alumn will warp
    Member Z28collection's Avatar
    chapin,s.c.
    black silver
    99 z28, 81 z28
    clutch
    im running billet steel flywheel and stage 4 Exedy clutch it has been great the last year or so it came as a package but it was $1500 plus.
    LTX N20LT4's Avatar
    Cali
    10's N/A
    Mc Leod twin-disc.
    Senior Member
    rochester,ny
    pewter
    2001 z28 lingenfelter 383
    love my ram hd so far.........had newera install it last yr and prolly have 3 or 4k miles on it
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    Textralia would be my choice. Will also back up the statement on the CenterForce, CRAP!!! lasted less than 6 months on my H/C combo. And not really a fan of SPEC, too many have had problems with them, to include me. You have about a 50/50 chance with them. No experience with the other mentioned clutches. The LS7 might hold up for a little while. And haven't really heard much on the RAMS, bad nor good. McLeod, supposedly a good choice too. Personally if I ever change mine, seriously considering a Tex twin disk.
    As for the aluminum flywheel, had one and the CenterForce scorched the crap out of it. Decided to go for billet steel.
    JUISSED Midnight02's Avatar
    Feb 2007
    Atlanta
    2002 Camaro SS
    +1 another vote for the LS7 clutch and LS2 steel flywheel. I haven't had any trouble with it on my H/C/I + spray car. That being said, I still have the stock 10 bolt and haven't throw a sticky tire on it and dumped hard from a dig. Once I get a 9" rear installed I'll give it a shot and let you guys know how it holds up.
    May 2008
    Germany (Hamburg)
    2002 Camaro SS
    Quote Originally Posted by TACE02 View Post
    Hi
    i have little question:
    you min centerforce is not that good or its ok?
    I wolte the center Force DFX kits Clutch buy
    oh sorry for my bad English
    Thank you
    chapin,s.c.
    black silver
    99 z28, 81 z28
    centerforce
    bad centerforce i had one in my stock tranny and it never grabbed good from the first day i had it. i put a rockland standard gear m6 with stage 4 exedy clutch and it is awesome.
  1. Whats a better upgrade?
    By jbwoof in forum General Help
    Last Post: 05-26-2011, 05:45 PM
  2. Clutch and flywheel upgrade
    By CCR90 in forum Corvette
    Last Post: 01-12-2011, 01:42 PM
  3. Question: clutch upgrade
    By 2000dreambird in forum Manual Transmission
    Last Post: 08-05-2009, 12:28 PM
  4. Question: LS7 Clutch Upgrade for 06 GTO
    By tazeo2 in forum Manual Transmission
    Last Post: 04-03-2008, 01:22 PM
  5. whats needed for a t56 upgrade
    By Qwk94Z28 in forum Manual Transmission
    Last Post: 01-07-2008, 08:47 AM
