    Junior Member vonny's Avatar
    May 2008
    Wi
    2002 Camaro SS 35th Convt
    Vats/BCM Problem
    I have a 2002 SS Camaro that has had alot of engine work/mods done as well as custom programmed computer. Every once in a while, it will crank over, but no injector action. I bypassed the vats system, and still does it (occasionally). I think its a bcm problem, but not sure?? The Scan tool says the security system is on when it acts up. How can I lie to the pcm so it doesnt do this anymore? Trying to fix without taking to GM dealership, Hacking car, or sending in pcm to remove vats. ANY suggestions are needed.
    Thanks! Vonny
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by vonny View Post
    Thanks! Vonny
    I can fix it, and if it's ONLY VATS, I will do it cheap, but you have to pull the PCM and send it to me. I know, you said you don't want to do that, but it's mail it off, goto the stealership, or find a local tuner..... or buy your own software of course.
    May 2008
    Wi
    How much do you charge, how long will you need it, and can you do it without changing the custom program already in it? Thanks for you help and quick reply!
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Yes I can do it without touching anything else at all. Sending a PM.
    -edit-
    Wait, new users don't have PM privelige, so send me an email to [email protected] for details.
  1. suspected vats problem
    By 37ute in forum General Help
    Last Post: 05-19-2015, 06:39 PM
  2. VATS problem?
    By slims00ls1z28 in forum GTO
    Last Post: 08-06-2011, 02:32 PM
  3. Question: vats problem? again?
    By 98maro in forum General Help
    Last Post: 02-15-2011, 11:42 AM
  4. VATS problem
    By ezwip in forum Computer & Tuning
    Last Post: 12-14-2009, 06:07 PM
  5. VATS????Security problem with the VATS.
    By LS1RacerMan30 in forum General Help
    Last Post: 07-14-2007, 07:39 AM
