Thread: vats problem? again?
02-13-2011, 03:46 PM #1Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
hey guys im back with more questions..
bout two months ago, i had a problem with the VATS it got fixed i did not by passed it,
so today started with a new thing.. when i want to start the car. it doesnt start at first when u open the switch to crank. only on the second try, it starts up with no problem.. the light (security) light is normal,
and some times cranks on the first the fist when u open the switch to crank but doenst start till second try..
could that be the vats again??
thanks in advace00 ss blk m6 " STOCK" strano springs, slp bilstein shocks, adj LCA, adj panhard bar, relocation brackets, 2 point SFCs welded,OEM zo6 rims black, magnaflow exhaust, CME exhaust,E/cutout, slp grille, custom front plate mount, HIDs, whistler mod, side moldings delete, slp air lid, ported and polished TB, strut tower brace, 3.73s gears, and some other parts to list!
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
02-13-2011, 03:51 PM #2
I would guess VATS, a relay on its way out, or a starter in its death throes.
02-13-2011, 04:26 PM #3
my bet on this one (assuming by "normal" you mean your security light is off) that it's a relay sticking. Try swapping that starter relay with your air pump relay and see what happens. It could also be a loose/corroded wire on the battery or your starter solenoid sticking.
02-13-2011, 04:34 PM #4Senior Member
- Feb 2010
the light is on when i open the switch (security ) sthe car starts after few secons is gone..
could it be the relay on the engine bay?
i remeber i opened my hood last night and i slamed it kinda hard,, could it be the relay is half way out or something?
cuz after few trys it starts up fine..
the car has power and everithing i dnt think it could be something related to battery, i could be wrong
02-15-2011, 11:25 AM #5Senior Member
- Feb 2010
Yup, is the vats again.
Stupid vats problem. Is a nightmare.
02-15-2011, 11:34 AM #6Electrical Engineer
- Jul 2009
- North of the Motorcity
Time for bypass?
I replaced my ignition cylinder and have had no problems in 3 years. I also keep no other keys on the key ring except the car keys as preventative maintenance.
02-15-2011, 11:42 AM #7Senior Member
- Feb 2010
I had the same problem. Last month.
The cylinder inside the switch. Abd I have the same problem as before.
The mechanic is coming to check it out for the warranty.
If he dnt wanna do it I'll ask for my money back.
And by pass it
suspected vats problem
By 37ute in forum General HelpReplies: 16Last Post: 05-19-2015, 06:39 PM -
VATS problem?
By slims00ls1z28 in forum GTOReplies: 2Last Post: 08-06-2011, 02:32 PM -
VATS problem
By ezwip in forum Computer & TuningReplies: 5Last Post: 12-14-2009, 06:07 PM -
Help: Vats/BCM Problem
By vonny in forum Computer & TuningReplies: 3Last Post: 05-13-2008, 03:06 PM -
VATS????Security problem with the VATS.
By LS1RacerMan30 in forum General HelpReplies: 14Last Post: 07-14-2007, 07:39 AM
