Results 1 to 3 of 3
    Member Camaroride32's Avatar
    Marathon, Fl
    Black/Silver Stripes
    2000 Trans am Ws6
    transmission problems
    Well i decided to do a clutch change... and when i got the tranny taken out, i discovered, the pilot bearing was pretty ground out and needles everywhere. So i took a look at the input shaft and its burned pretty bad. Im just curious, what are signs of the input shaft being bad, and how is the pilot bearing suppose to sit on the input shaft?? The tranny has 110,000 miles so maybe ill just send it out and get it rebuild.
    Member Fran D's Avatar
    Washington Crossing, PA
    If you can see that the input shaft has been scored, it's not a very good idea to throw it back in without freshening it up. Granted, it could last a while, but at 110K miles, why place that bet? You've already got the trans out. Take the time, now, to get it rebuilt.
    metro Detroit area
    The damage done when operating with a bad pilot bearing goes deeper than the pilot journal finish. The real damage is to the "pocket" bearing . It is the bearing that guides the mainshaft to the input gear. It is located on the mainshaft with a race in the input shaft. Only a teardown will show its condition.
  1. Help: Transmission problems.
    By schug93 in forum General Help
    Last Post: 10-30-2011, 06:38 PM
  2. Help: I think its transmission problems now....
    By Big Steel in forum Manual Transmission
    Last Post: 08-21-2011, 12:59 PM
  3. Question: C5 transmission problems
    By Edgar Limon in forum Corvette
    Last Post: 12-30-2009, 04:57 AM
  4. Help: transmission problems
    By hutcher04 in forum Manual Transmission
    Last Post: 05-25-2008, 07:17 PM
  5. transmission problems
    By Missy in forum Automatic Transmission
    Last Post: 10-22-2005, 03:48 PM
