12-18-2005, 02:51 PM #1Senior Member
- Sep 2005
- New York, NY
Collectors Edition Yellow- 2002 Pontiac Trans AM WS6
When making a hard left i hear a rubbing sounding noise???
I have no klew what this noise is but what i head is when i cut the wheel left semi-hard when comming around the turn and let say the turns are about 45 degrees... I hear what sounds to be a rubbing/groaning noise around the passenger front tire... .It DOESNT do this when i turn hard to the right only the left... Maybe the left shock is done and is creating too much body roll to that side i have no idea...... Any ideas???
12-18-2005, 05:47 PM #2
1st, when parked, turn the wheels all the way so that you car see the fender well, look for scrap marks on the plactic shield inside the well, 2nd look at your tire for rubbing damage. Next, get a good alignment, and have the tech check your camber/toe angles. You may have that wheel off just enough to rub and this needs to be taked care of ASAP !!
12-18-2005, 10:22 PM #3Senior Member
- Sep 2005
- New York, NY
Yea i definatly need to figure out what it is... Oh and to make a correction... its when i make a sharp right turn that the left wheel makes noise... Dunno if that makes any difference but i will check tommrow to see if there is any rubbing..
12-27-2005, 12:06 PM #4
hub bearing most likely on the right side.
Making a hard choice
By nomolos1 in forum Southern MembersReplies: 5Last Post: 05-02-2011, 05:53 PM -
T-Top Squeak/Rubbing Noise
By regerror6 in forum Firebird / WS6Replies: 15Last Post: 09-21-2008, 04:57 AM -
Pump sounding noise
By gareth001 in forum Camaro / SSReplies: 3Last Post: 07-23-2007, 02:33 PM -
Slipping feel when making left turns.
By seasponge in forum DrivetrainReplies: 4Last Post: 07-23-2007, 05:41 AM -
Tire rubbing noise during hard right corners.
By Blkls1 in forum Suspension and HandlingReplies: 1Last Post: 12-30-2005, 09:51 AM
