Results 1 to 2 of 2
12-29-2005, 08:12 PM #1Blkls1Guest
Tire rubbing noise during hard right corners.
I just recently starting hearing a tire rubbing noise comming from the rear drivers side fender/tire well. It gets real bad when i really get into a hard right corner (like an on ramp). I adjusted my kyb shocks to the most firm adjustment. It got a lilttle better but not much. I jacked the car up today and can see tire marks on the bottom rear inner well, towards the front and rub marks on the back of the tire. Even a rub mark on my traction bars??? Anyways i cant think of any reason why it just started rubbing I havent changed any thing and it has never done this in the past.
Could this be a rear alignment problem? The only thing I can think of is about a week ago, I did lose control of the car for a split second and the driver side slamed into the center divide pretty good. No serious damage. Scatched the rear wheel pretty good and the front ground effect, and put a small gash in the front tire. Everything seems to still be ok in the rear when I jacked it up.
12-30-2005, 09:51 AM #2
look to see if you bent the panhard rod. that keeps the rear center with the vehicle.
Question: Biggest front tire size w/o rubbing
By davidz28 in forum Wheels and TiresReplies: 16Last Post: 06-15-2011, 12:34 PM -
c5 vette rims, tire rubbing?
By ggino85 in forum General HelpReplies: 7Last Post: 05-30-2010, 08:25 AM -
T-Top Squeak/Rubbing Noise
By regerror6 in forum Firebird / WS6Replies: 15Last Post: 09-21-2008, 04:57 AM -
cracking noise on hard acceleration
By zetwentyeight in forum Automatic TransmissionReplies: 1Last Post: 12-18-2006, 01:18 PM -
When making a hard left i hear a rubbing sounding noise???
By NeeD4SpeeD in forum Suspension and HandlingReplies: 3Last Post: 12-27-2005, 12:06 PM
