Thread: 5.3 bore
    May 2008
    hendersonville
    flat black
    1953 business coupe
    5.3 bore
    how far can u bore it safe. its iron
    Member 99transamC/FIA's Avatar
    Jun 2006
    DETROIT
    PEWTER
    99 TRANS AM
    3.905 Max
    May 2008
    hendersonville
    flat black
    1953 business coupe
    man I was hoping to go 2 a conventional 4.000 bore
    May 2008
    hendersonville
    flat black
    1953 business coupe
    how big of a stroke will fit in it
    Jun 2006
    DETROIT
    PEWTER
    99 TRANS AM
    4.00" will drop in with a little grinding. 4.25" will go with lots ($500-$700)of machine work.
    Run the 3.905 bore with 4.00 crank for a 383cuin 15* small block. With the right cam and mild ported heads will easily make 500+HP.Dont be afried of the small bore the difference is only a couple of HP's.
  1. Question: hub center bore
    By 98TransAmWs-6 in forum Wheels and Tires
    Last Post: 06-03-2012, 05:51 PM
  2. Question: How much to bore?
    By farmer_ron_99 in forum Internal Engine
    Last Post: 08-04-2009, 08:51 AM
  3. Max bore on iron 6.0l
    By crankshaft in forum Internal Engine
    Last Post: 06-04-2009, 10:31 AM
  4. Max bore on 6.2l?
    By 99transamC/FIA in forum General Help
    Last Post: 08-14-2008, 01:35 PM
  5. bore
    By 01tao6gto in forum Internal Engine
    Last Post: 11-15-2007, 09:30 PM
