Results 1 to 3 of 3
Thread: hub center bore
06-03-2012, 01:42 PM #1Senior Member
- Apr 2010
- Alabama
hub center bore
I am trying to find the correct 30mm spacer with it's own studs for my car. I have been searching but have been unable to find the front hub center bore measurement. I was wondering what the center bore of the front hub was? I have found things that said 70.3mm and 70.5mm but I want to double check what it is. If no one knows, then how do you measure it, from outside to outside or inside to inside?
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
06-03-2012, 05:28 PM #211 years of bangin gears
- Jan 2009
- North Jersey
I could be wrong, but I believe it is outside to outside.
06-03-2012, 05:51 PM #3Senior Member
- Apr 2010
- Alabama
Okay that is what I thought. I am thinking I will need a digital caliper to get the accurate measurement unless someone knows what it is or where I can find such information.
Question: Bore sizes
By CHEETAHRON in forum Internal EngineReplies: 2Last Post: 06-04-2011, 02:33 AM -
Question: How much to bore?
By farmer_ron_99 in forum Internal EngineReplies: 2Last Post: 08-04-2009, 08:51 AM -
Max bore on 6.2l?
By 99transamC/FIA in forum General HelpReplies: 0Last Post: 08-14-2008, 01:35 PM -
5.3 bore
By 53chevy in forum Internal EngineReplies: 4Last Post: 05-17-2008, 01:16 PM -
bore
By 01tao6gto in forum Internal EngineReplies: 2Last Post: 11-15-2007, 09:30 PM
