Results 1 to 3 of 3
    Hawaii
    Couple Questions.
    Ok i have a 2000 Trans Am WS6 that was wrecked. and had some frame damage. So since i missed driving the car so much i just bought an 98 Trans am. And i still have the 2000 and was wondering if i could just swap out the PCM or is it more complicated then that? And my second question is if i deiced to put the motor from the 2000 in the 98 would i have to get the computer programed? or is it fine the way it is? Has less miles on it is why i was maybe thinking of swamping the motors. But even if i don't swap i want to know if i can just swap the PCM Just buy plugging the new one in or what.. thanks
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    you would have to move the wiring harness over as well, to use the 2000 PCM.
    swapping motors only does not need to have the PCM reprogrammed.
    if you do swap the motor, might as well move the harness over as well.
    Hawaii
    Thanks.. Do i also have to swap out teh cluster? from what im reading the cluster is diffrent from the 98-00? And then what would i do about the milage sence the one on my 00 is less?
  1. couple of lt1 questions
    By dirttrax in forum LT1
    Last Post: 02-13-2010, 10:57 AM
  2. new guy with a couple questions.
    By QCSV in forum New Member Introductions
    Last Post: 08-24-2009, 11:31 AM
  3. couple of questions
    By ddmfla in forum New Member Introductions
    Last Post: 03-20-2009, 07:31 AM
  4. couple questions
    By joegtox in forum GTO
    Last Post: 04-15-2007, 10:39 PM
  5. Couple questions.
    By fright88 in forum Rocky Mountain Members
    Last Post: 11-05-2006, 09:27 PM
