Results 1 to 20 of 21
Thread: couple of lt1 questions
02-04-2010, 07:43 PM #1Junior Member
- Apr 2009
- tn
Is the lt1 internal or external balanced?
And what is stock compression on a 93 lt1?
also while im getting motor rebuilt, if i go with flatops can I deck the block or heads without messing up knock sensors or computer? or should I just leave compression alone?
02-04-2010, 09:20 PM #2
The lt1 is internally balanced with a weighted flex plate or flywheel. If you replace these items you need a stock weighted one to replace them but the balancer should be neutral or zero balanced. There have been some cases were people say they have run across a weighted balancer but I have never seen it. As for the compression, the stock ratio is already higher than normal at 10.25 to 10.50 to 1. If you increase it you are going to increase the chances of detonation with out a tune. As for the piston that is a question for the engine builder as you need to know what cam, rocker ratio, deck height, head and the thickness of the head being used. Basically you need to calculate out the distance between the piston and the valve through the valves duration from open to close. There are all types of lifts and durrations so this can change based on the cam and type of piston used. Tons of guys have used preformance cams on stock heads and bottom ends so it is usually not a problem untill you get in to changing the pistons to 0cc flat top or +cc or dome piston.
02-04-2010, 11:20 PM #3Junior Member
- Apr 2009
- tn
Ok sounds like I will leave compression where it is. But now Im confused on the balance, If it internal balance why have a weighted flywheel? I guess im just thinking of older style, like the 400 thats externally balanced with weights. not debating you just trying to learn something from you, thanks alot.
02-05-2010, 05:25 AM #4
I don't know man I know they call it internally ballanced but it has weights lol.
02-05-2010, 10:42 AM #5
02-05-2010, 06:53 PM #6Member
- Feb 2008
- Russellville, MO
The flywheel has wieghts because the LT1 is actually a split balance. The front portion of the engine is a neutral balance but the back half is balanced, this is why there is a weight on the flywheel. At least that is what I was told.
02-09-2010, 09:05 AM #7Junior Member
- Apr 2009
- tn
02-09-2010, 12:22 PM #8
02-09-2010, 01:42 PM #9
02-09-2010, 03:14 PM #10Junior Member
- Apr 2009
- tn
02-10-2010, 03:50 PM #11Junior Member
- Apr 2009
- tn
Still need an answer if anyone knows, thanks
02-10-2010, 04:29 PM #12
02-10-2010, 09:35 PM #13Junior Member
- Apr 2009
- tn
02-12-2010, 10:36 AM #14
02-12-2010, 11:13 AM #15Junior Member
- Apr 2009
- tn
02-12-2010, 11:53 AM #16
I don't know about that but I did read somewhere long ago about the LT1 and that the crank was more like a 305 crank because the 305 was supposed to be internally ballanced while the 350 was externally balanced. I think it was just to compare but I would go to a parts store and see if they have them in stock and set a 305 5 speed fly wheel next to a 350 5 speed fly wheel and an lt1 6speed flywheel and see if the either of them look to be close to the lt1 6 speed. Thats what I would do, and then you can see if they are weighted the same. or you might just find someone to wieght the 5 speed flywheel to the lt1 flywheel specs.
02-12-2010, 12:35 PM #17
Or just save a bunch of headache and find an LT1 flywheel.
02-12-2010, 09:23 PM #18Junior Member
- Apr 2009
- tn
well finally found the answer, 86 and up chevrolet does have a counter weighted flywheel.
I fyou click the link and look at page four it tells the answer.
http://www.s-series.org/htm/tech/GMP...ts/076-081.pdf
02-12-2010, 09:26 PM #19Junior Member
- Apr 2009
- tn
02-13-2010, 07:58 AM #20
Are all gm flex and flywheels weighted the same? is that what this link says? it sounds like all of the one piece rear seal cranks use the same wieghted flex or fly. Just diff sizes.
Question: a couple of questions
By phoenix05 in forum Firebird / WS6Replies: 1Last Post: 02-07-2009, 10:46 AM -
couple questions
By joegtox in forum GTOReplies: 11Last Post: 04-15-2007, 10:39 PM -
Couple questions.
By fright88 in forum Rocky Mountain MembersReplies: 4Last Post: 11-05-2006, 09:27 PM
