Thread: what size power wire
12-17-2005, 07:13 PM #1
i am planning my new system and already picked up a few pieces. I only want to run the power wire once, so i was thinking that if i put a large enough one i could i could branch off in the rear if i make changes. i picked up a 5 channel mtx 25x4 rms and 100 rms to the sub. i was thinking of running two amps, bridging the mtx to get 100 rms by two and another amp i have laying around for the rears 50x2 rms. what guage wire should i run so i wont have to do it again?
12-17-2005, 07:47 PM #2
- Jul 2005
- OHIO Go Buckeyes!
Arctic White- '07 Trailblazer LT
4awg wire from the battery to a distribution block in the back of the car should be plenty big enough for your needs. You could then run 8awg to each amplifier from the D-block.
12-17-2005, 08:24 PM #3
no less than 4ga. 0/1 if you feel like you might expand it even more and don't want to buy wire again later.
12-18-2005, 01:39 AM #4
- Sep 2005
- Richardson, TX
S.O.M- 2001 Firebird
4 gauge would be fine for that. just make sure you upgrade the wiring in the engine bay as well if it isn't 4 gauge... (ex: the ground cable, etc)
12-18-2005, 05:39 AM #5
Those amps 4 gauge will work .Then split power to the amps.If you are even thinking of getting in the 1000 watt class for thump go 1/0 gauge as stated.Because Subs
usually lead to more power for componets.
Hawk2001 Firehawk looking
for more power !
01-02-2006, 07:54 PM #6FingermoosingGuest
Ive always been told to never use different gauge wire, if you use 4 awg wire from the battery to the dist. block then 4 awg should come out to the amp too.
01-02-2006, 09:11 PM #7
- Jul 2005
- OHIO Go Buckeyes!
Originally Posted by Fingermoosing
4awg from the battery to the D-block and then 8awg from the D-block to the amp is OK. The run from the D-block to amp will be much shorter than the run from the battery.
What Size Electrical Wire Should I Run?
By Ed Blown Vert in forum General HelpReplies: 1Last Post: 06-26-2013, 10:26 PM -
Help: What is the Monsoon Power Wire?
By SMWS6TA in forum Stereo and ElectronicsReplies: 5Last Post: 07-27-2010, 11:42 AM -
power wire??
By 96cherrybird in forum General HelpReplies: 5Last Post: 06-01-2009, 01:57 PM -
Power Wire
By SamD_Ind in forum Stereo and ElectronicsReplies: 0Last Post: 04-24-2008, 07:58 AM -
Power Wire
By Soltakr in forum Stereo and ElectronicsReplies: 3Last Post: 03-29-2007, 07:58 AM
