Results 1 to 2 of 2
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Exclamation What Size Electrical Wire Should I Run?
    Whether scratch-building a complete wiring harness or lengthening kit-supplied wires, you need to determine the correct electrical wire size needed to support each electrical device.Whether scratch-building a complete wiring harness or lengthening kit-supplied wires, you need to determine the correct electrical wire size needed to support each electrical device. The wire must carry the required current without overheating and burning, and without excessive voltage drop.
    a
    Photo Gallery: What Size Electrical Wire Should I Run? - Hot Rod Magazine
    What Size Electrical Wire Should I Run? | Digg It | Add to del.icio.us
    More...
    this would be good knowledge to have.....I normally cheat and use online calculators. Looking this over step 3 is confusing me. How do they get .0644 from .00299 x 10ft??
  1. LS1 valley cover bolt size, what size?
    By Blue28 in forum External Engine
    Last Post: 10-03-2009, 05:47 PM
  2. Question: What size wheel studs? OEM size?
    By x10-wakerider in forum Wheels and Tires
    Last Post: 06-20-2009, 08:26 AM
  3. electrical?
    By stangnightmare in forum General Help
    Last Post: 03-05-2007, 12:58 PM
  4. Electrical HELP!!! PLEASE
    By TimC in forum General Help
    Last Post: 05-26-2006, 08:39 AM
  5. what size power wire
    By fastws6 in forum Stereo and Electronics
    Last Post: 01-02-2006, 09:11 PM
