    doylestown, Pa
    SILVER
    2004 CTS-V
    Where to mount boost and fuel pressure guage?
    First off, my heading is wrong.
    I just got a Procharger for my LS1 F-body. I have a fuel pressure and boost guage to install.
    My first question is, how do I connect the fuel pressure line to rhe fuel rail?
    Second question is, where do I connect the boost gauge line? I have seen it connected to the power brake booster line, but where is the best place?
    Pics would definitly help! Thanks
    doylestown, Pa
    SILVER
    2004 CTS-V
    Come on peeps!
    aurora colorado
    2002 TRANS AM WS6
    There is a shrader? valve on the front of the fuel rail under the black cap on the driver side. You have to remove the shraider valve and hookup the fuel pressure sending unit to the fuel rail. Sorry no pics but there is a t-fitting on the passanger side fire wall next to the pcm. It's a small black tube about the same size as the boost gauge tube, if you can't find it it is connected at the back of the intake manifold on the pass side. Make sure you hook up to the end that connects to the intake there is a one way check valve on the other side of the t-fitting so it wont see vacuum.
    doylestown, Pa
    SILVER
    2004 CTS-V
    62 views and one reply?
    Member 99transamC/FIA's Avatar
    Jun 2006
    DETROIT
    PEWTER
    99 TRANS AM
    Just like he said. Sounded like good direction to me!
    Areoquip sells the fitting you need for the fuel rails $10 buck i think.
    doylestown, Pa
    SILVER
    2004 CTS-V
    Is that the best place for the boost line?
    doylestown, Pa
    SILVER
    2004 CTS-V
    Sometimes I don't understand the amount of views to replys ??
    Jun 2006
    DETROIT
    PEWTER
    99 TRANS AM
    Yes that is the best place.Unless you pull the intake a make a fitting to use the MAP sensor port.Every turbo car i bulid here that is where i put them for ease of install. you can run the line through the firewall with the computer wires.
    Good luck
  1. Question: Fuel Rail pressure Guage
    By kingls1 in forum General Help
    Last Post: 06-19-2016, 03:31 PM
  2. fuel pressure guage
    By WS6S in forum Firebird / WS6
    Last Post: 06-07-2011, 09:48 PM
  3. For Sale: White Dash Relay / Blue Liquid Fuel Pressure Guage
    By Castle in forum Parts For Sale / Trade
    Last Post: 03-18-2008, 11:47 PM
  4. BOOST gauge, FUEL PRESSURE gauge, dual pillar pod
    By onefastbird! in forum Parts Wanted / Trade
    Last Post: 04-26-2007, 08:31 PM
  5. FUEL PRESSURE, AND A/F GUAGE F/S or F/T
    By stangkiller2005 in forum Parts For Sale / Trade
    Last Post: 10-14-2006, 08:26 AM
