Results 1 to 18 of 18
Thread: fuel pressure guage
06-04-2011, 07:31 PM #1middle aged teenager
- Nov 2009
- lawrenceville georgia
sunset orange/ black- two 2001 ws6 m6
fuel pressure guage
i bought one of those liquid filled fuel pressure guages and im not sure how to mount it on the stock fuel rail,can it be done ?
06-05-2011, 10:57 AM #2
you have to have the adapters to make it work. the easiest way to connect it is at the fuel rail. there is a fuel port connection on the Driver's side portion of the fuel rail.
06-05-2011, 06:06 PM #3
06-05-2011, 06:40 PM #4middle aged teenager
- Nov 2009
got it thanks brothers
06-05-2011, 07:05 PM #5
06-06-2011, 03:05 AM #6
99% sure that it is an Autometer that I ordered from Summit or Jeg's.
Just a note to the OP: To install the sender, you have to remove the valve from the end of the fuel rail or the gauge will not work. It is done in the same fashion as removing a tire valve from a valve stem.
06-06-2011, 04:12 AM #7
Are you installing an electronic one like shown with a sender? Or one which will just stay in the engine bay?
I have an old one that I just might add to the engine bay to keep watch on pressure when manually throttling the engine.
06-06-2011, 07:41 AM #8
06-06-2011, 01:30 PM #9middle aged teenager
- Nov 2009
jayta98 thats what i have,mechanical not elec...
06-06-2011, 01:43 PM #10
i dont know the size of the port at the fuel rail. i can suggest to take off the plastic cap that screws on it and go to a hardware store and find an adapter. With the cap im sure they can help you figure out the right size adapter you need. take the gauge with you as well.
06-06-2011, 03:04 PM #11middle aged teenager
- Nov 2009
it actually came with an elbow and an adaptor but the adaptor needs to plunge the pin in on the valve to release the pressure and it doesnt
06-06-2011, 05:39 PM #12
06-06-2011, 05:50 PM #13
06-07-2011, 04:03 AM #14middle aged teenager
- Nov 2009
sweeet thanks...
06-07-2011, 05:10 AM #15
06-07-2011, 10:07 AM #16
06-07-2011, 10:11 AM #17
06-07-2011, 09:48 PM #18middle aged teenager
- Nov 2009
ok easy as pie,installed in a few minutes.thanks for the input...
Question: Fuel Rail pressure Guage
By kingls1 in forum General HelpReplies: 15Last Post: 06-19-2016, 03:31 PM -
Where to mount boost and fuel pressure guage?
By 9t8z28 in forum Forced InductionReplies: 7Last Post: 05-17-2008, 01:10 PM -
For Sale: White Dash Relay / Blue Liquid Fuel Pressure Guage
By Castle in forum Parts For Sale / TradeReplies: 0Last Post: 03-18-2008, 11:47 PM -
FUEL PRESSURE, AND A/F GUAGE F/S or F/T
By stangkiller2005 in forum Parts For Sale / TradeReplies: 4Last Post: 10-14-2006, 08:26 AM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 03:59 PM
