Results 1 to 11 of 11
Thread: How to build
    Junior Member hartsmike's Avatar
    Feb 2008
    tennessee
    How to build
    I've got 180,000 miles and am looking at a rebuild. How do/can I build it to where I wont have to get a brand new computer. I.E bore, cam things like that.
    94 T.A. Lt1
    Thanks,
    Aug 2006
    Missouri
    94 Camaro Z28
    Uh, you don't have to get a new computer, you just get it tuned through the PCM via mail-order tune or dyno tune.
    Senior Member Sleeper101's Avatar
    Springcity
    Vette,240sx,ls1 camaro
    Keep the stock cam/heads/ and sensors. Internal work doesn't hurt it. A stroker bottom end with a Stock top end works fine without tuning.
    Aug 2006
    Missouri
    94 Camaro Z28
    If you stroke it, won't you still need to adjust the injectors and timing?
    Springcity
    Quote Originally Posted by BlackLT1Z28 View Post
    We didn't on mine. Went 383, with Stock ECU tune and it run fine.
    Feb 2008
    tennessee
    As far as head work and cam, what can be done. I'm a huge fan of hitting cams but, I'm also aware that the computer recognizes that as a miss.
    I've seen advertisements for cams on line but don't know if they will actually work.
    Springcity
    Heads and cam can be changed to anything you want to put on it. You just have to get the ECU tuned on a Dyno. Here it costs about 500$ to get tuned b/c you have to buy the program.
    Feb 2008
    tennessee
    I guess it is better to take it and have it tuned than to order a tune Huh?
    I've heard so many stories where when people build hot motors that the computer never gets it right. Does that happen alot?
    Springcity
    I would never trust a computer tuned and shipped to ya. only the Dyno will tell how the motor is re-acting, Almost every engine is different, So the tune will be a little different. So taking the car to get tuned would be smarter yes.
    Feb 2008
    tennessee
    If the motor is "built" will it be difficult for the computer to maintain the proper function?
    I know a guy that bought a salvaged z28 and built it for the drag strip. He said the computer never ran right. I've also heard a few similar stories. What do you guys know?
    Feb 2008
    tennessee
    bumpidy bump bump.
  1. 78 LS1 TA build
    By reedld in forum LSx Retrofit and Swap
    Last Post: 07-11-2014, 06:41 PM
  2. 440 LSX build
    By cam02ss in forum Camaro / SS
    Last Post: 07-01-2013, 03:55 AM
  3. 78 LS1 TA build
    By reedld in forum Classic Muscle
    Last Post: 04-23-2013, 07:40 PM
  4. Hot Rod Mag LS1 build
    By racingrev in forum Camaro / SS
    Last Post: 09-01-2010, 09:39 AM
  5. 500CI Chevy LS1 Engine Build - How To Build A 500C
    Last Post: 02-17-2009, 07:10 PM
