Results 1 to 10 of 10
Thread: 440 LSX build
    Purcellville, VA
    440 LSX build
    I sent a rod through the side of the 408 and also through the oil pan. It wasn't pretty and I wasn't the track favorite that day. So- here we go again. Big cube, high compression build.
    440 ci LSX, 14.5:1 compression ratio, solid roller
    -Mast Motorsports 305cc "big bore" heads with Pac 950 lbs springs, Titanium intake/ Inconel exhaust valves
    -Bullet Racing Cam 280/298 799/782 114 LSA
    -Manton 1/2" pushrods
    -Isky Red Zone Lifters
    -Callies Dragonslayer crank
    -Callies I beam rods
    -Wiseco pistsons
    -Mast Motorsports/Carys 4500 series intake
    -Accufab 4500 series throttle body
    -Wilson Pro Flo 350hp nitrous plate system
    -Aviaid dry sump oil system
    -Holly Dominator series EFI computer
    -Midwest Chassis FAB9 rear w/ Strange center section 4.11 gears
    -ATI reverse manual valve body TH400 transmission
    -Circle D 5200 stall converter
    -Magnafuel external fuel pump/fuel system
    -Mini tubbed
    -Pharro Performance custom front bumper support
    - Weld RTS rims with Mickey Thompson drag radials
    -Aerospace drag brakes
    -Burkhart Racing manual steering
    -Burkhart Racing tubular K member, tubular A arms
    -VFN Sunoco fiberglass hood
    Here's a shot from this past Friday....it's coming along
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Nice build...when are we racing?
    Purcellville, VA
    Dry sump is plumbed and the Holly EFI is wired with a base tune loaded in. The Nasty Performance fabricated valve covers I used on the 408 didn't clear the new rockers so I ordered a new set from All Pro, which will be delivered today. The car cranks but won't turn over- ditched the red top for a new battery and ran a new ground cable. If the starter is shot I'll go with a Tilton.
    College Station TX
    2000 &2002 Z28
    This is Frank from Facebook, damn that is bad ass man. Did you build the motor yourself?
    Those specs are out of this world haha.
    Would love to see more on this car.
    Purcellville, VA
    Hey man, thanks. No I had the motor professionally built. I'll have some videos and stuff up once the car is cleaned up and on the dyno.
    Subscribed. How does this compare to your last engine?
    Purcellville, VA
    I should have upgraded the rods from Callies H to I beams and put a dry sump on the last motor, for the RPMs I was trying to turn. It was a 9 sec NA motor all day long and had more potential left in it. The 408 was 13.6:1 and had TF 235 heads and a big cam in it. From what I was told to expect out of my 440, it would have taken a 250 shot on top of the old motor to equal what this one will make NA.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Drop a dime on us when you get it to the track. I am going to say 8.7 sec
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Where you at with this?
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    Been meaning to find and sub to this. Hope all is going well with the build.
  1. 78 LS1 TA build
    By reedld in forum LSx Retrofit and Swap
    Last Post: 07-11-2014, 06:41 PM
  2. 78 LS1 TA build
    By reedld in forum Classic Muscle
    Last Post: 04-23-2013, 07:40 PM
  3. Hot Rod Mag LS1 build
    By racingrev in forum Camaro / SS
    Last Post: 09-01-2010, 09:39 AM
  4. 500CI Chevy LS1 Engine Build - How To Build A 500C
    Last Post: 02-17-2009, 07:10 PM
  5. I want to build up the .....
    By clg82 in forum Drivetrain
    Last Post: 09-01-2007, 11:06 AM
