Results 1 to 17 of 17
Thread: Too much body flex
04-30-2008, 12:05 PM #1Junior Member
- Apr 2008
- Ft Worth
Green- 94 TA GT
Too much body flex
Anyone have any ideas on how to stiffen up the car so there is not so much body flex? Is there an under hood support I can add or anything else I can do to the car to get some of the body flex out of it?
04-30-2008, 12:48 PM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Front strut tower brace, roll bar,sub frame connectors.....
05-01-2008, 06:35 AM #3
i have SFC's and Panhard bar, and strut tower brace, its pretty stiff
RK sport makes a set of SFC's for verts, theyre good and cheap too
05-01-2008, 06:49 AM #4Junior Member
- Apr 2008
- Ft Worth
Green- 94 TA GT
05-01-2008, 09:41 AM #5
umi fabrication, bolt on sfcs, panhard, stb, etc.
Regards,
Todd
#cajunhotrodder on instagram
05-02-2008, 02:57 PM #6
I've got the UMI front strut support on mine, pair that with weld in sub frames and it will take out some of the twist.
05-04-2008, 03:10 AM #7
I recommend weld-in SFCs first, they strengthen the most flexible part (mid-car) on the vert chassis. You will notice the car feeling much more rigid and handling better
05-09-2008, 06:25 AM #8Junior Member
- Apr 2008
- Ft Worth
Green- 94 TA GT
Installed a strut tower brace yesterday, and it seems to have made an improvement. Sub frame connectors are on order and will do them next.
05-10-2008, 01:28 AM #9
Anyone try the UMI bolt in SFC's yet? Been thinking of getting some. Going to check out the RK sport site to see if they are any cheaper.
05-31-2008, 09:56 AM #10
Installed BMR'S SFC, LCA, Strut Tower Brace,QA1 adjustable shocks, and Ajustable Panhard Bar... And I love it.
05-31-2008, 10:02 AM #11
I put on a STB and it was alot better, but the twist especially under
hard accel. was sooooooooooo much better after the SFC I got a set of
Kennny Browns and had them welded
wish i would have done it sooner
05-31-2008, 11:40 PM #12Crazy Canuck !
- Jun 2002
- Montreal, CANADA
SFCs + Rollbar.
Eugenio_SS
06-01-2008, 02:57 AM #13
I'll find out next week how these affect ride and handling as I bought UMI bolt in sfc and got a used set of lca's. Looking forward to doing some wrenching!
06-01-2008, 05:28 AM #14
Rollcage.....
Black 00 SS M6, vert, #0540 408ci
DD 2014 Sierra All Terrain
06-01-2008, 08:21 AM #15
Weld In SFC first. Bolt ins are better than nothing but from past experience those lock nuts just never stay tight enough and you have to check em from time to time to keep the creaking away.
06-07-2008, 05:58 PM #16
Did my install this week and have to say I'm pretty impressed!No more creaking and groaning over bumps,takes curves better and feels more fun to drive.Haven't seen any down side yet.If bolts start coming loose then I'll see about getting them welded.
06-08-2008, 05:57 PM #17Crazy Canuck !
- Jun 2002
- Montreal, CANADA
even after the stb, sfc, rollbar, i still get dimples in my rear quarter panel due to cornering forces @ the track w/ sticky rubber... had them fixed at least twice...
2009 Ford Flex - Hot Rod Ford Flex
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 08-10-2009, 10:00 PM -
T-top flex!!!
By JoshieDoom in forum Firebird / WS6Replies: 23Last Post: 09-30-2008, 09:56 AM -
What flex plate?
By Iwanaturbo in forum Automatic TransmissionReplies: 3Last Post: 04-16-2008, 04:41 AM -
Help: Flex plate rub
By SStriker in forum Automatic TransmissionReplies: 2Last Post: 03-01-2008, 01:41 PM -
Body Flex
By WS6ICK in forum General HelpReplies: 20Last Post: 11-29-2005, 01:43 PM
