Results 1 to 20 of 21
Thread: Body Flex
    JMAC Racing WS6ICK's Avatar
    Kentucky
    2000 Trans Am WS6 LS6
    2006 GTO LS2
    Body Flex
    I have s 2000 TA, WS6, Ram Air. Can anyone tell me what sounds the body make when it flexes. I know I need to get SFC installed but I am wondering if the sounds my car makes is the body flexing. It only does it at dead stop takeoff. It does not do it when I am doing 20-30-40 and kick, only at dead stop and kick. I hear a poping sound coming from about the center of the car. I have checked the rear end, Transmission, Driveshaft, u joints and front end but I cant seem to find anything wrong.
    Chicago
    Blue
    2001 TA WS6
    I'm by be wrong..
    but i hade poping sound in my car and it was a craked rear sway bar
    but then againg i my wrong
    Hope it helps
    how about the tq arm? if your kickin' at launch that's gotta be tq arm.
    Kentucky
    2006 GTO LS2
    I have replaced both the rear tq arms, Sway Bars and the panhard bar with aftermarket ones from BMR. I also went through and greased all of them.
    redls1bird
    Guest
    do you have aftermarket exhaust? sometimes the exhaust will rub theunder body on hard accelleration.
    Kentucky
    2006 GTO LS2
    Yes, I have flowmaster catback with a custom y-pipe but the exhaust has been checked.
    redls1bird
    Guest
    has been checked how? have you ever looked for rub marks or anything of the sort?
    Kentucky
    2006 GTO LS2
    yes
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Tranny mount or exhaust is my guess
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    To answer your question -the body flex can be heard in various parts of the car.In my car only thing I hear is the t-tops sometimes going over rough pavement.I would think the popping sound is not from body flex but from drivetrain or suspension as you have already been told.If you have poly bushings in some of the aftermarket stuff I would be very suspious of this as they are notorious for making noises.As far as the exhaust goes you need to look closely at the clearances around the pipes-aftermarket exhaust doesnt always have enough room around it for every possible situation-it's bigger in diameter and wasnt made by GM.Torque arm is the likely culprit-however sometimes a problem has to get worse before it can be found and that may very well be the case.Get out and get under it on a regular basis and keep looking,you'll figure it out before somebody else will.
    Kentucky
    2006 GTO LS2
    I finally just took the car to a local shop to have it checked out. I found out it was the Y-Pipe rubbing against the underside of the body. When I get on it, the engine would torque and make the driver side Y-Pipe hit under the car. I just have to take it back to the Muffler shop and have them weld on a brace. Thanks to all who responded.
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Glad you found it. It sounded like an exhaust pipe issue while I just read this thread. That is somewhat common on our cars with aftermarket exhausts.
    Virginia Beach, VA
    2000 SS
    Can you post a pic of the place where your new bracket is welded?
    Kentucky
    2006 GTO LS2
    Sure, Give me a fews days and I will post a pic. I have to get it in the air to do this.
    Senior Member Hurley711's Avatar
    Earth
    414 RWHP 395 RWTQ
    00 Black Ram Air Trans Am
    Am I THE ONLY ONE who read that second post? The first response????WTF???
    THE SWAMP
    2000 Camaro SS M6
    Dat be un fine produk of publik scool edjukashun.
    Earth
    414 RWHP 395 RWTQ
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Quote Originally Posted by Hurley711
    No, you werent the only one -but after spending 5 minutes translating it into english I was too tired to make fun of it. People-spend some time on your spelling so other people can read it ,or nobody's going to appreciate what you are trying to say.
    Earth
    414 RWHP 395 RWTQ
    Someone needs to translate it side by side because I just don't understand that mother f'er
    Modding is an Addiction bww3588's Avatar
    Chillicothe, Ohio
    no more beer for him!
  1. 2009 Ford Flex - Hot Rod Ford Flex
    Last Post: 08-10-2009, 10:00 PM
  2. T-top flex!!!
    By JoshieDoom in forum Firebird / WS6
    Last Post: 09-30-2008, 09:56 AM
  3. Too much body flex
    By Fred H. in forum Convertible
    Last Post: 06-08-2008, 05:57 PM
  4. What flex plate?
    By Iwanaturbo in forum Automatic Transmission
    Last Post: 04-16-2008, 04:41 AM
  5. Help: Flex plate rub
    By SStriker in forum Automatic Transmission
    Last Post: 03-01-2008, 01:41 PM
