    Import Killer camarostripes96's Avatar
    Aug 2006
    academy,tx
    1996 Trans am
    which way do the header gaskets go?
    i have the copper header gasket from mr. gasket, and one side is raised and the other side is flat , which way goes towards the head?
    Arizona
    I haven't tried Mr. Gasket,,,but the copper gaskets I use tells you to put the flat side to the head and the raised portion facing the headers.
    Aug 2006
    Missouri
    94 Camaro Z28
    That's how I set up my OE gaskets.
    Aug 2006
    academy,tx
    1996 Trans am
    Ok now I'm confused on the air delete. Does the air have a silenoid?
    Arizona
    Quote Originally Posted by camarostripes96 View Post
    Yes it does have a control solenoid for the A.I.R.,,,,on my 97 it's mounted up on the passenger side intake. Not sure about the earlier years. Your vacuum diagram under the hood should lead you to it.
  1. header gaskets
    By basballny2 in forum External Engine
    Last Post: 09-06-2009, 07:58 PM
  2. Question: header gaskets
    By TransAmFanatic in forum General Help
    Last Post: 04-03-2008, 06:45 PM
  3. header gaskets
    By Rare99Firehawk in forum External Engine
    Last Post: 09-14-2007, 04:05 AM
  4. Header gaskets
    By luvmyz28 in forum External Engine
    Last Post: 06-15-2007, 02:11 PM
  5. Header Gaskets
    By tav8ws6 in forum External Engine
    Last Post: 03-19-2007, 05:45 AM
