Results 1 to 10 of 10
Thread: header gaskets
03-31-2008, 03:51 PM #1
header gaskets
ok i put some slp long tubes on my 99 t/a about a month ago, and im having a problem. the header gaskets that that i got from slp did not seal well with the headers, so my question is that what kind of gaskets should i get?
03-31-2008, 04:54 PM #2Member
- Dec 2007
- Minnesota
pewter- 2002 Tans am WS6 M6
Had the same problem but with Edelbrock. Anyway what I did was buy these dead soft aluminum gaskets and this Hight Temp gasket seal in a tube and have had absolulty no probs.
2002 Trans Am WS6 M6
04-01-2008, 12:45 PM #3
where can i get those gaskets and the seal?
04-01-2008, 12:57 PM #4My Neighbors Hate Me!!!
- Jun 2006
- Ft. Lee, Virginia
Artic White- 2001 Chevy Camaro SS
I think you should just get some stock gm gaskets. Here's the part #12617944.
04-01-2008, 02:21 PM #5
04-01-2008, 04:30 PM #6
OEM work just fine, Make sure when you replace the gaskets you tightin all of your bolts equaly.
04-01-2008, 04:36 PM #7
use Percy's dead soft aluminum. they have header and collector gaskets. these are great and you can get them from Jegs or Oriellys or Autozone. header gaskets are about $46 and the collector is about $16
04-01-2008, 06:20 PM #8Member
- Tulsa,OK
Quick Silver- 2002 Z06
OEM GM gaskets should work just fine. Make sure you tighten them evenly like said above. Inside out. Also torque them to specs. I'm sitting on a year and almost 15,000 miles on my SLP's with no issue at all.
You can use the other brand above just the same but the GM gaskets should work just fine unless the headers are warped or something.
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
04-01-2008, 08:13 PM #9
It's been my personal experience that stock gm>Percys
04-03-2008, 06:45 PM #10Member
- Dec 2007
- Minnesota
Perceys is what I got and just ordered it out of a mag. The seal was from an auto part store
LS1 Header Gaskets (OEM)
By tpilews in forum Parts For Sale / TradeReplies: 4Last Post: 05-18-2011, 03:50 PM -
header gaskets
By basballny2 in forum External EngineReplies: 7Last Post: 09-06-2009, 07:58 PM -
header gaskets
By Rare99Firehawk in forum External EngineReplies: 7Last Post: 09-14-2007, 04:05 AM -
Header gaskets
By luvmyz28 in forum External EngineReplies: 5Last Post: 06-15-2007, 02:11 PM -
Header Gaskets
By tav8ws6 in forum External EngineReplies: 8Last Post: 03-19-2007, 05:45 AM
