Thread: electrical problem
04-29-2008, 05:26 AM #1
electrical problem
Ok guy's I have a 98 firebird with the LS1 in it. the problem is all my lights flicker from bright to dim and my volt gauge is also flickering up and down. I though it may be a bad ground so i added a grounding strap and it still does it. has anyone else had this issue or know a cure for this. Thanks Wade
04-29-2008, 05:45 AM #2
You're alternator may be going bad. Autozone can check it for free.
04-29-2008, 05:52 AM #3Senior Member
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
yeah prob alternator
04-29-2008, 07:07 AM #4
Yepp, get your charging system checked, also make sure your battery terminals are good and tight and clean. Just curious but where did you "Add" a ground?
04-29-2008, 07:08 AM #5
04-29-2008, 07:23 AM #6
if you have a multimeter you can put it across the battery terminals with the car running and see what your voltage is doing there. It should be ~14.4 volts and pretty steady. Like those guys said, sounds like a possible alternator issue.
05-01-2008, 12:57 PM #7Junior Member
- Apr 2006
- boston
Bright Red- 1998 Trans Am WS-6
Mine was doing the same thing...I replaced my alt today and everything is fine now...you might think about you battery as well.
Electrical Problem
By Pewter WS-6 in forum Stereo and ElectronicsReplies: 10Last Post: 05-18-2010, 05:27 PM -
Electrical Problem NEED HELP!!
By camarostripes96 in forum Stereo and ElectronicsReplies: 3Last Post: 04-25-2008, 03:55 PM -
Help: Electrical Problem
By tiny47 in forum Stereo and ElectronicsReplies: 3Last Post: 04-19-2008, 11:14 AM -
Electrical/charging problem problem
By jchcomputers in forum General HelpReplies: 4Last Post: 02-23-2007, 05:59 AM
