Results 1 to 11 of 11
Thread: Quick Performance INC, rearends
04-21-2008, 08:35 PM #1
Have you guys heard about this place? what do you guys think about this prices? my car is a a4 2001 ss and i was thinkin to get one from this place. heres the info.
$895 - 9" Ford Housing/Axle Package (2001 Camaro)
- Includes Torque-Arm Bracket
- GM Flush Mount Housing Ends (Allows use of factory brakes)
- Moser Axles, Axle Bearings, Wheel Studs, & Retainers
- 31 Spline, 5 on 4-3/4" Bolt Pattern, 1/2" Studs
$1145 - Center Section (Assembled)
- Strange Nodular Iron S-Case
- Aluminum Daytona Pinion Support
- 1350 Forged Steel Yoke
- Motive Performance Gears (Choice of Ratio)
- 31 Spline Trac-Lock Posi
- Timken USA Bearings
good? or is there a better place with better price for the rearend?
04-22-2008, 12:43 AM #22 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
I bought mine through Quick Performance raceing. Outstanding prices and customer service was top notch. They will beat anyone elses price.
I got the same deal but with a Strange pro Nodular case, 35 spline axles, detroit locker, and Motive Performance 4.30 gears. I paid a little more but got a better third member.
Don't forget about a drain and fill plug. You'll thank me later.2000 SS Camaro Heads, Large cam, Fast 90, 9"w/430's and locker, yada yada yada... you get the picture
04-22-2008, 08:01 AM #3
how much was yours all together? whats the diff betwen the 31 and the 35? i was goin to go with the 373 gears tho.
04-22-2008, 08:37 AM #4Junior Member
- Mar 2008
- Baltimore, MD
Don't forget bout Autofab Race Cars.....killer deal on strange and moser rears....410 796 8777 ask for Josh
04-22-2008, 09:10 AM #5
o sweet thx..ill take a look at that too
04-22-2008, 04:45 PM #62 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
Mine was $2500 shipped but I also got New reluctor rings and pressed onto the axles. The detroit locker and the Pro nodular Third member is quite a bit more as well.
The more spline count of the axles the stronger the axles is, So a 35 splined axle is stronger than a 31 splined axle. But unless you are putting down some serious HP (550+) 31 splined axles will be fine. (Stock 10 bolt axles are only 28 spline)
04-22-2008, 05:13 PM #7Member
- Aug 2007
- Marathon, Fl
Black/Silver Stripes- 2000 Trans am Ws6
whats the diff between all the center section cases they offer??
04-23-2008, 03:16 PM #82 SS's are better than 1
- Jun 2007
- Lathrop, Missouri
They offer just about any brand third member you want. I am just more partial to Strange (However they do not make a 9" for the new gen f-body) Thats why I got a hybrid type rear end.
The Strange "S" case is a little stronger than a stock ford nodular case and is good up to about 450 HP. The Pro nodular case is 33% stronger and can take just about any kind of abuse you can throw at it.
Moser thrd members are much better than a stock one but like I said I am more partial to strange.
If I had the money, a Mark Williams third member would be the one I would choose but they are real proud of their product, and are quite expensive.
04-23-2008, 03:46 PM #9Member
- Aug 2007
- Marathon, Fl
so if im planning to be pushing about 500hp then the ford 9 inch center section and S case will be vulnerable to break??
04-23-2008, 06:24 PM #10
05-10-2008, 04:25 PM #11
hey jays00ss, is it worth getting the ABS and the tru traction? its like 300$ more.
Spool rearends
By shadowbandit in forum DrivetrainReplies: 5Last Post: 12-16-2014, 03:00 PM -
Quick Performance Question.
By StangEater77 in forum Camaro / SSReplies: 4Last Post: 03-01-2012, 06:31 PM -
Firebird RearEnds, Are they 10 bolts?
By SMWS6TA in forum General HelpReplies: 6Last Post: 01-22-2012, 07:47 PM -
Quick Time Performance Headers ?
By Corona-Extra in forum External EngineReplies: 5Last Post: 06-08-2006, 06:07 PM
