    Firebird RearEnds, Are they 10 bolts?
    Do Firebirds (98-02) share the same rear ends (10 bolts) as their big brothers?
    (Sorry, I lazy in my old age to go into a junk yard and jack up a wreak and lay under it just to see if it does)
    I'm asking because I'm researching for a project and I know where I can get 2 Firebird rear ends, cheap.
    (I don't want the gears, just the axle tubes.)
    Thanks
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    the rear ends are exactly the same minus the ratios. v6 cars came with open differentials stock with a 3.08 ratio for an auto and 3.23 with a manual . optional was a 3.42 for the auto and a posi unit could also be ordered
    Good because like I said I just want them for the axle tubes.....
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    What are you planning to do, Scott? Reinforce your current rear?
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Hopefully he's building a trailor and needs an axle for it......
    I may be experimenting with an 8.8 rear build and need the axle tubes.
    I want to get 2 extra 10 bolts so that if I make a mistake I have a spare if needed.
    I will not drop the one that is currently in mine to experiment on. It's still working fine for now, but it's a major hurdle in future power plans that needs to be address. 8.8's seem to be just as tough as 9" and if SPAZ hasn't killed his by now it must be a tough SOB. I've been researching and it seems there is a good enough aftermarket support in gears, axles, etc... that this may be an affordable alternative to dropping 3k on a 9" or 12 bolt.
    The major hurdle I've found is getting the 2 metals to weld right. That takes a skill welder and I am not one, however I know one and he has loads of experence in building rock crawlers and mud bugs/trucks.
    North Jersey
    2004 GTO M6
    OK. There is a member here who put an 8.8 from an Explorer into his SS. I can't think of his screenname for the life of me unfortunately.
  1. Spool rearends
    By shadowbandit in forum Drivetrain
    Last Post: 12-16-2014, 03:00 PM
  2. For Sale: New Moser 12 bolts and 9" Rearends
    By LSx Heaven in forum Parts For Sale / Trade
    Last Post: 07-29-2009, 06:44 AM
  3. Quick Performance INC, rearends
    By Hot SS in forum Drivetrain
    Last Post: 05-10-2008, 04:25 PM
