Thread: Turn Signal problem
04-15-2008, 05:35 PM #1Member
- Aug 2007
- Marathon, Fl
Black/Silver Stripes- 2000 Trans am Ws6
Turn Signal problem
When i go to click to the right turn signal... some times itll work... and other times i have to push up really hard on the turn signal lever and hold it to make it work... if i let it drop down to where it should hold the turn signal will disengage w/o disengaging the lever. Any idea if its the lever or something else??
04-15-2008, 07:09 PM #2
It is caused by a certain position that you have your wheel in at that time. There is nothing wrong with it, but it takes some getting use to when you come up to intersections and go to switch it on.
04-16-2008, 03:18 AM #3Member
- Aug 2007
- Marathon, Fl
no it has nothing to do w/ the steering wheel... i kno when you turn the steering wheel it will disengage.... this stays engage it just doesent come on....
04-16-2008, 03:23 PM #4Member
- Tulsa,OK
Quick Silver- 2002 Z06
Only thing it can be is the mechanisim in the steering wheel. Not that big a deal to change you will just need a steering wheel puller and the new part.
Someone can probably chime in on a part number.
Camaro Owners Click Here
Firebird Owners Click Here
www.AutoTrix.net
turn signal problem?
By DMAN in forum General HelpReplies: 6Last Post: 10-25-2010, 04:21 PM -
turn signal problem
By Firebirdformula in forum Firebird / WS6Replies: 7Last Post: 06-07-2010, 04:55 PM -
Left Turn Signal Problem
By 6speedTAthistime in forum Firebird / WS6Replies: 6Last Post: 11-21-2007, 06:53 PM -
Turn signal problem
By {FzS}BlacKMagicK in forum General HelpReplies: 10Last Post: 05-01-2007, 05:27 AM -
Turn Signal Problem
By M.RedWS6 in forum Firebird / WS6Replies: 5Last Post: 11-25-2006, 10:02 AM
